Electrical Help/conversion? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 11:19 PM   #1
Electrical help/conversion?
I am looking to convert this setup to be able to install my own fixture (it's above my bar). I am not sure on what I need to do. I can provide more info as needed.
Breakthecycle2 is offline   Reply With Quote
Old 05-13-2011, 12:13 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I cannot tell what I am even looking at. Can you downsize the pics? and maybe back up and take a pic we can see what we are looking at?
Old 05-13-2011, 10:30 AM   #3
It's kind of hard because it's over the bar and there is limited space. I will try in a few and take a wider pic.
Old 05-13-2011, 11:11 AM   #4
I=E/R
a7ecorsair's Avatar
It looks like there is some type of fixture box with greenfield entering and exiting. The two bronze sockets are somehow connected to the fixture box.
If you take another picture, turn down your resolution and turn off the flash.
a7ecorsair is offline   Reply With Quote
Old 05-13-2011, 12:07 PM   #5
Like I said it's really hard to get into the space with the camera, but the light bulb sockets are directly attached to round "boxes".
Old 05-15-2011, 03:57 PM   #6
ANy ideas?
Old 05-15-2011, 05:13 PM   #7
nap
You talking to me?
nap's Avatar
well, I don't see anything legal about the installation you have. It's about the most improper install I have seen in awhile.
So, what would you like to do? What kind of fixture do you want to install?
Old 05-15-2011, 07:03 PM   #8
I was thinking the same thing. Id like to put some small high hats in that area.
Old 05-15-2011, 07:34 PM   #9
nap
You talking to me?
nap's Avatar
Ok, what is the ceiling made of? I see what looks like a drywall ceiling but it it looks like it might not be screwed directly to the joists. Is the opening I see in the pics going to remain?
Old 05-15-2011, 08:42 PM   #10
Yes, the opening will remain, depending on what lights I do. Believe it or not, that section of the ceiling is wood.
Old 05-18-2011, 03:24 PM   #11
OK, need some quick help guys. Its tough to tell from the pics, but the spot is tight (less the 7" wide). The light bulb sockets are plugged directly into a round "eletrical box". How do I get the sockts out?
Old 05-18-2011, 03:59 PM   #12
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Does the cable go into and out of the round box?
The best thing I see to do is remove the box from the joist and let hang to see how everything is mounted.
Old 05-18-2011, 07:05 PM   #13
Yeah its connected both in and out. I was afraid Id have to do that because the area is so tight to get into.
Old Bathroom - all electrical on one circuit? how to change? Steve19 Electrical 16 03-14-2011 09:32 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
