Electrical Help - Electrical - DIY Chatroom Home Improvement Forum
Old 07-15-2013, 02:06 PM   #1
Electrical help
Hi I have a consumer unit that keeps tripping the main breaker even when there arnt any circuit on. Does anyone have any suggestions what it could be
Dale smith is offline   Reply With Quote
Old 07-15-2013, 02:16 PM   #2
Oso954's Avatar
Rewards Points: 1,670
He is speaking English. Unfortunately it seems to be the Queens English, not North American English.
The consumer unit is a panel. I've seen them as a sub panel for a flat or apartment. But he might be talking about a main for a house.
Oso954 is offline   Reply With Quote
Old 07-15-2013, 02:20 PM   #3
Rewards Points: 6,652
If they are tripping the main breaker, they have serious issues that they need to have a professional licensed electrician come in and look at the system.
Old 07-15-2013, 02:39 PM   #4
Work done
I have an electrician rewiring my house and he isn't sure what the problem is he has put be cables in for the sockets but they are not wired into the consumer unit ( panel) and the main rcd just trips do you know what it could be please
Old 07-15-2013, 02:59 PM   #5
Oso954's Avatar
If your "electrician" can't figure it out, you need a new electrician.
The Following User Says Thank You to Oso954 For This Useful Post:
Philly Master (07-16-2013)
Old 07-15-2013, 03:05 PM   #6
Find another Electrician. And no, none of us would know, because we are not physically there, and you are only giving information in bits and pieces, as if you are sending a message by Text Messaging, or using Twitter.
Helps if you give out more detailed information as to how this started, what the electrician did to cause this problem, what kind of changes they did to cause the problem. Then tell them they are fired, and hire a competent licensed professional electrician that knows what they are doing.
Old 07-15-2013, 06:09 PM   #7
Rewards Points: 150
When does it trip? Can you turn it on and it will hold ? Does it take time to trip?
RIP EJT
usair is offline   Reply With Quote
Old 07-15-2013, 11:02 PM   #8
Electrical Enthusiast
Rewards Points: 504
Is this one of those special RCD main breakers?
I agree with the above comments...if you've got nothing connected in the consumer unit there is no reason for it to trip....
Kyle_in_rure is offline   Reply With Quote
Old 07-15-2013, 11:09 PM   #9
" Euro " electrician
frenchelectrican's Avatar
The way I read sound like you have unqualifed electrician try to do that work.
Have that electrician updated to the 17th edition ( British Codes ) ?
The main RCD trip which tell me that the system is not being wired properly espcally with crossed connection.
The biggest bugger you will hate is combation of old colour standard and new colour standard and if not aware what is going on that why the main RCD is tripping without load on it.
Get someone else who is more qualifed to do this.
And tell that new electrician to megger ( PAT testing ) the whole thing I am not suprised that you have mixed bag or radial and ring circuit in that place.
Merci,
Marc
French Master Electrician.
The Following User Says Thank You to frenchelectrican For This Useful Post:
gregzoll (07-16-2013)
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
