Electrical Help. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 09:21 PM   #16
Resi EC
Rewards Points: 252
Originally Posted by bobelectric View Post
I don't get why a switch controling a closet light would also control a bedroom receptacle.
Maybe someone added the closet light and just came off the closest switch
Gac66610 is offline   Reply With Quote
Old 05-27-2013, 09:58 PM   #17
I will be working on it tomorrow, I will take and post pictures then. Should the outlet in the room be a standard 15-amp outlet rather than a GFCI? I have a feeling the previous owner did not know what he was doing, and could have put that in by mistake.
tomdellaquila is offline   Reply With Quote
Old 05-28-2013, 12:53 PM   #18
Brian58Fraga's Avatar
Step #1 disconnect all wires at GFCI
Step#2 disconnect all wires at light switch
Step#3 disconnect all wires at switched receptacle
Step#4 separate all wires (so not touching) turn power on test wires (black to white)to find "hot" tag both hot and neutral wire feed then turn power off. If feed wire is at your GFCI then hook up both black wires under line hot screw and both white wires under line neutral screw if you don't want your light and plug GFCI protected.
Step#5 repeat step 4 at switch box if power went to GFCI first, if you want your switched receptacle to be hot perminantly hot then tie your black wire with the hot/ feed black wire not the switch leg!
Brian58Fraga is offline   Reply With Quote
Old 05-28-2013, 01:31 PM   #19
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
IMHO. They added the gfi so they would have 3 prong...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-28-2013, 02:37 PM   #20
Here are pictures of the switch and outlet.
Old 05-28-2013, 06:29 PM   #21
I opened up a switch and outlet in another room to compare, wired everything identically, and the switch, the closet light, the outlet, and the outdoor outlet work perfectly. Thank you everyone for your help!
The Following 2 Users Say Thank You to tomdellaquila For This Useful Post:
Philly Master (05-28-2013), sirsparksalot (05-29-2013)
Tags
electrical , light switches , outlets , residential , wiring
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
