Electrical Help. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 02:38 PM   #1
Electrical help.
I am having trouble with the wiring in my house. I have a light switch in my room that use to control a light in the closet, and an outlet in the room. Additionally, I have a backyard outlet that all use to work. My light switch broke, and my neighbor tried to change it for me. This only made things worse, as nothing is working now. In the light switch in the room, there are three sets of wires. One red, black, and white set, one white and black coming from the closet light, and one white and black set. In the outlet in the room, there is one red, black, and white set, and one white and black set. This outlet is like one you would find in a bathroom or a kitchen, it has a reset and test button on it. Outside, the backyard outlet has a white and black wire. Any help to get all three working again would be greatly appreciated. Thank you.
tomdellaquila is offline   Reply With Quote
Old 05-27-2013, 05:04 PM   #2
Rewards Points: 506
What are the wires coming from the GFCI in the room?
Can a GFCI be split-wired?
Installation is the Reverse of Removal.
Old 05-27-2013, 06:13 PM   #3
Not sure of the original configuration. My neighbor took that apart without noting the original wiring.
Old 05-27-2013, 06:34 PM   #4
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Is there a Ground wire( bare copper ) that is as big as the red or black or white wire in the oulet box ??
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-27-2013, 08:26 PM   #5
There is no ground in the outlet box. The electrical is original to the house, it was built in the late 50s.
Old 05-27-2013, 09:01 PM   #6
Resi EC
Rewards Points: 252
If all was working before the switch was replaced, I would suspect something is wired wrong there.
First, have you checked the breaker/fuse to make sure it's on/good?
Gac66610 is offline   Reply With Quote
Old 05-27-2013, 09:24 PM   #7
Yes, everything is ok there.
Old 05-27-2013, 09:32 PM   #8
Resi EC
Rewards Points: 252
Can you post a pic of switch? Should have all whites twisted together and tucked into the back of the box, the black from closet light and red for receptacle twisted together and pigtailed to a switch terminal, the rest of blacks twisted together and pigtail to the other terminal of switch.
Old 05-27-2013, 09:42 PM   #9
Rewards Points: 506
I really don't think you can switch half of a GFCI (which is the one with the TEST and RESET buttons).
Please post pics.
Old 05-27-2013, 09:59 PM   #10
Rewards Points: 1,192
Tie grounds together,put in box.Tie whites together, put in box. Tie reds together,put in box.Tie blacks together with tail for switch. Black for closet light goes to other terminal on switch.
bobelectric is offline   Reply With Quote
Old 05-27-2013, 10:00 PM   #11
Resi EC
Rewards Points: 252
Please post pics.
Correct, you can not half switch a GFCI receptacle, missed that, maybe the whole thing is switched?
Need pic of switch and GFCI wiring, please
Old 05-27-2013, 10:04 PM   #12
Rewards Points: 506
Originally Posted by bobelectric View Post
Tie gounds together,put in box.Tie whites together, put in box. Tie reds together,put in box.Tie blacks together with tail for switch. Black for closet light goes to other terminal on switch. Voila!
And this makes the GFCI half-switched?
Old 05-27-2013, 10:10 PM   #13
Rewards Points: 506
Here's what I came up with, half-assed though it may be.
Old 05-27-2013, 10:15 PM   #14
I don't get why a switch controling a closet light would also control a bedroom receptacle.
Old 05-27-2013, 10:19 PM   #15
Resi EC
Rewards Points: 252
That's how I read the OP also, did say there was another black and white leaving the recpt., I was assuming it went to the outside recept.
As you have suggested, half switching a GFCI is not fesible.
I would guess the red wire needs to be disconnected from both the switch and recpt. wire nutted off and tucked into the boxes
Tags
electrical , light switches , outlets , residential , wiring
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
