Electrical Help! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 09:58 AM   #16
Cheers thanks folks, off to run a wire
Nathanm is offline   Reply With Quote
Old 04-30-2012, 09:58 AM   #17
Rewards Points: 2,516
Originally Posted by Nathanm View Post
So I will have to run another switch I can't tap into the loop behind the light for power and have both fan and light run from the one switch already installed?
You need to get a neutral at the location for the exhaust fan.
hammerlane is offline   Reply With Quote
Old 04-30-2012, 10:12 AM   #18
After further reading this, yes you can operate both devices off of one switch:whatever cable you have running from the light box to the fan box, the black wire of this cable(cable to fan box) gets wire nutted into the return power from the switch. The white wire of the cable going to the fan gets wire nutted into the other neutrals at the light box.
See diagram.
Old 04-30-2012, 07:21 PM   #19
Success!!!! Thanks for the help everyone, sorry for the ignorance not knowing what was going on. Your help made all the difference in the world
Old 05-01-2012, 06:27 AM   #20
which way did you do it. Did you install a new switch or did you run both off of the existing switch?
Old 05-01-2012, 06:58 AM   #21
I ended up running a second switch works like a charm now.
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
