Electrical Fused Disconnect - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 09:42 AM   #1
I am currently planning to have a local electrical contractor upgrade my 70 amp electrical panel to 100 or more. He has just informed me that the estimate he had originally quote will have to be increased due to my electrical supply company where I live requiring him to install a special devise call a electrical fuse disconnect which must be rated at not less than 56000 volts/amps. Dose this make sense? Such a device has never been in place for the more than 30 years I have owned to property.
Baker John is offline   Reply With Quote
Old 07-08-2011, 10:00 AM   #2
Rewards Points: 130
Find a new electrician. Hes not being truthful or he does not know what he is doing. First of all, an electrical supply company does not make any rules regarding installation. He may be trying to up sell you on something you may not need. Ask another contractor or two.
Do not take any advice from non-licensed electricians. Make them show you their license.
Old 07-08-2011, 10:02 AM   #3
Master Electrician
Rewards Points: 3,826
Sounds strange but I think the OP is referring to the POCO.
brric is offline   Reply With Quote
Old 07-08-2011, 10:57 AM   #4
joed's Avatar
Rewards Points: 12,458
Sounds like a disconnect for the POCO out at the pole. More details required as this does not sound like something the electrician would install. Maybe the POCO is installing it and billing you for it through the electrician.
Old 07-08-2011, 05:46 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,928
Did you mean "56000 amp interrupt capacity" perhaps? Sounds like the power company is requiring the service equipment to handle higher fault current than usual for residential services. The solution to that is to installed a "fused disconnect" with a 56k AIC rating ahead of the new panel. Are you in a dense urban area?
mpoulton is offline   Reply With Quote
Old 07-08-2011, 07:58 PM   #6
Electrical Contractor
kbsparky's Avatar
Call your power company and ask them to provide you with their available fault-current for your location. You might have to ask for their engineering dept.
IF it's over 20,000 Amps, then a standard panel box may not provide sufficient protection.
Let us know your results.
-KB
Old 07-08-2011, 08:01 PM   #7
kbsparky's Avatar
... an electrical supply company does not make any rules regarding installation. He may be trying to up sell you on something you may not need.....
The OP may be confusing an electrical supply company with a power company. He may not know that the usual term for a supply company usually means a wholesale house.
-KB
Old 07-08-2011, 09:59 PM   #8
" Euro " electrician
frenchelectrican's Avatar
That is true I have ran into the same situation espcally with dense network supply and I know once you pass 22KIA it will open new can of worms { that in USA side the French side typically once you get over 14KIA it the same situation as you guys are }
Merci.
Marc
Old 07-09-2011, 12:21 AM   #9
Idiot Emeritus
Rewards Points: 1,492
56,000 amps is pretty much unheard of for available fault current on a single phase service. I really don't know how you'd get that much.
Suppose the transformer is 167KVA. That's huge, a 75KVA one will feed about a dozen houses, but for the sake of argument, well use a 167.
The full-load current of this transformer is 696 amps.
If the transformer is 4% impedance (Pretty low, most would be 6 or 7%), the short circuit current will be 17,400 amps.
And that's at the transformer, it'll be less at the meter.
A 500KVA transformer at 4% impedance would have a short circuit rating of 52,083 amps. You'll never see a transformer that big installed in a residential subdivision though; it'd feed around 100 houses, and the secondary conductors would be over 1000' long to get to the last house.
I don't see how a disconnect with that interrupting rating would be needed. I get the idea that someone is trying to sell you something you don't need.
micromind is offline   Reply With Quote
Old 07-09-2011, 04:51 AM   #10
It is a crazy high number, but it's at least theoretically possible. As Marc said, it could happen on a network distribution system. That's why I asked if it was a dense urban area.
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Oven - 230v - disconnect? CZSteve Electrical 2 06-13-2010 05:56 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
