Electrical Feed To Barn - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 05:28 AM   #16
Electrician
SD515's Avatar
Rewards Points: 504
Can't re-color a #6 in conduit. #6 insulated has to be green or green with yellow stripes.
I agree though...an insulated conductor will pull much easier.
Kyle
Old 06-08-2011, 08:18 AM   #17
Thanks guys . I have the subpanel figured out . Two hots to breaker, neutral to neutral bar, ground to unbonded ground strip. then a # 6 copper from ground bar to (2) 8 ft ground rods. Right???? Now at the main panel is the neutral and ground bonded or isolated. Thanks for all the help.
Jxl062643 is offline   Reply With Quote
Old 06-08-2011, 08:25 AM   #18
Electrician
SD515's Avatar
Rewards Points: 504
Ground bar in your sub-panel gets mounted to the tub, thus bonding it to the tub. In the sub, the neutral and grounds are isolated from each other. The neutral bar should already be mounted on an isolated, plastic stand. Do not use any bonding screw, strap, bar, etc. that may have come with the panel. If they’re installed, remove them.
At your main panel, the necessary bonding between the neutral and ground should already be there. You shouldn’t have to do anything else in the main panel.
Kyle
Old 06-08-2011, 09:19 AM   #19
I ask the impossible!
Rewards Points: 692
Yeah, should be able to get #6 THHN in green at the big box stores, they'll have 500' spools or you can get the length you want cut from a spool.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
My old barn roof collapsed starchild General DIY Discussions 5 02-08-2011 01:15 PM
Grounding Panel at Barn EWW Electrical 4 12-23-2010 11:15 AM
How much power can i give my new barn? DonQ2010 Electrical 16 09-08-2010 09:23 AM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
