Electrical Failures In House - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2009, 03:19 PM   #1
Electrical Failures in House
Hi everyone this is my first time posting here. I have a situation that I would like some advice on. I just bought a house about 3 months ago and I have been experiencing frequent failures with electronic devices around my house. So far it has been 3 laptop chargers, 1 xbox 360, 1 Playstation 2, my dishwasher just quit working today (had garbled display ever since i moved in) and my dryer displays PF (power failure) on occasion. Could this just be one big coincidence or could there be something more going on? Is there any kind of DIY way of monitoring the power in my house and maybe some way to regulate it if there is a problem. Thanks alot
- Dave
Rafterman414 is offline   Reply With Quote
Old 01-23-2009, 03:26 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I'd have someone come out and check for a loose service neutral.
Do you notice any other strange things going on (lights dimming/brighten)?
wirenut1110 is offline   Reply With Quote
Old 01-23-2009, 03:37 PM   #3
I have not noticed any light dimming around the house, I have noticed that my power bill is gigantic, about 290 this month even though I hardly ever use the heater.
Old 01-23-2009, 03:44 PM   #4
Rewards Points: 510
Honestly, I'd just have the power company come out and check their stuff, eliminate that and it's free.
Someone else may have other ideas.
Old 01-23-2009, 03:59 PM   #5
Res Ipsa Loquitur
Agreed- do what doesn't cost you first and eliminate the POCO problems if there are any.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 01-23-2009, 05:40 PM   #6
In addition to the above, it is a good idea to get a "whole house surge protector" installed at your main electric panel and use good quality surge protectors at each outlet where you have something electronic plugged in.
This is expensive, but much less than the cost of replacing these things because there was a "voltage surge".
Billy_Bob is offline   Reply With Quote
Old 01-23-2009, 06:10 PM   #7
Rewards Points: 1,538
Have you made any voltage measurements? For starters you don't need a continuous graphed readout. Measurements every few hours on different circuits will suffice.
As far as a gigantic power bill goes, have you tested circuits by turning them off except for one at a time turned on and observed the electric meter (easier with older meters that have a spinning disk)? This will help to narrow down on where power is being consumed and lead you to the appliance or device consuming excessive amounts. Maybe you have electric equipment such as roof ice melting cables you never knew you owned.
Do you have an electric water heater and leaks in the hot water pipes and/or faucets?
AllanJ is online now   Reply With Quote
Old 01-23-2009, 06:28 PM   #8
Well the power people just came out and said that their reading was 246v, they said that was good so I dunno what to do now lol. Guess ill buy some good surge protectors.
Old 01-23-2009, 07:00 PM   #9
I'm not sure your stuff is ruined; they may just have their brains scrambled by frequent dropouts. Pursue the remedy with the manufacturers. We had a dishwasher like that.
Lobby the power company to put a recording voltmeter on your line. They won't like to do that one bit and they may report that everything is fine, and then you have no more dropouts (this happened to customers of mine).
They don't want to replace degraded power line insulation any more than public officials want to use money to fix bridges instead of spending the money on their mistresses.
You could also buy a tiny UPS and try it with some of your computer stuff.
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Questions about upgrading electrical stuff in our house Trisha Electrical 8 01-16-2009 06:26 AM
new homeowner, electrical questions bobblehead Electrical 3 01-14-2009 08:46 PM
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
No House Wrap On New House JoeZ430 Building & Construction 34 11-29-2007 10:51 AM
