Old 04-29-2012, 08:53 PM   #16
Electrical extension question
Originally Posted by k_buz
If you thought that was OK, you shouldn't touch anything else electrical.
That's why I asked. I hope I don't have to touch any more. The wiring for the shop was done before I added the stud walls.
bkanneg is offline   Reply With Quote
Old 04-29-2012, 10:27 PM   #17
joed's Avatar
Also run the cable through the studs instead of behind them and staple it within a foot of the box. If you are going to continue to run the cable behind the studs then you must fasten it every 4 feet.
I would say the guy that ran those cable was no electrician.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 04-29-2012, 10:31 PM   #18
I=E/R
a7ecorsair's Avatar
That's a little unusual..
a7ecorsair is offline   Reply With Quote
Old 04-29-2012, 10:39 PM   #19
yeah, i'm confused as well now. the wires were just laying there and then you put up the walls? not necessarily a problem but it seems weird.
itsnotrequired is offline   Reply With Quote
Old 04-29-2012, 11:28 PM   #20
It is a metal pole barn that doesn't come with traditional stud walls. I'm trying to separate some of the space into a different room so am putting up the walls myself. Does that explain it? I can post more pics if you need them.
Old 04-29-2012, 11:39 PM   #21
kevinp22's Avatar
please do post more pics -you have piqued our collective curiosity
anyone who has done any wiring (whether a pro or a DIY like me) has uncovered such splices behind walls, or in the case of my house, just laying on insultation in attics
kevinp22 is offline   Reply With Quote
Old 04-29-2012, 11:51 PM   #22
Here are a couple of more pics. It is a 30 x 50 pole barn. It doesn't have stud walls as built, but I have been adding them so I can add insulation and drywall. The electrician wired it and attached the boxes to the horizontal 2x6s in the pics. I have been moving the boxes to the vertical studs as I build them.
Electrical extension question-image-216406111.jpg   Electrical extension question-image-677009627.jpg   Electrical extension question-image-1921131952.jpg   Electrical extension question-image-530213641.jpg
Old 04-30-2012, 12:01 AM   #23
kevinp22's Avatar
1. id kill for all that space
2. i agree with others about pulling the wires through studs in the holes and stapling, etc
What size service did you run for the building?
Old 04-30-2012, 07:06 PM   #24
Thanks to everyone for the input. Does this look a little better?
Electrical extension question-image-2074528906.jpg   Electrical extension question-image-2160543588.jpg
Old 04-30-2012, 07:37 PM   #25
Only one cable per hole/friction clamp in that plastic box.
Also why didnt you drill holes thru the studs?
hammerlane is offline   Reply With Quote
Old 04-30-2012, 07:59 PM   #26
Licensed Electrician
k_buz's Avatar
With that running board, I wouldn't have drilled the studs either.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
darren (04-30-2012), jbfan (04-30-2012)
Old 04-30-2012, 08:13 PM   #27
The pic doesn't show it but I have one cable in the top hole and one in the bottom. Is that ok?
Old 04-30-2012, 08:14 PM   #28
Electrician
Do you have to worry about vapour barrier or is that built into the outside walls.
One wire in bottom and one in top is fine.
darren is offline   Reply With Quote
Old 04-30-2012, 08:43 PM   #29
The outside of the building is metal. The inside is wrapped by double bubble insulation. Is that considered a vapor barrier?
Old 04-30-2012, 09:44 PM   #30
Licensed electrician
Single gang boxes do not have clamps, just knockouts. The KO's can accept two cables.
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 10:19 AM
well pump electrical multimeter question tpolk Electrical 21 04-28-2010 11:37 PM
Question about electrical shock chewing cords sljacobs Electrical 12 02-25-2010 10:36 AM
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 09:03 AM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
