Electrical (energy Questions From Noob) - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 10:16 PM   #1
Electrical (energy questions from noob)
hi,
I have some basic questions about lightning that I'm setting up. I decided to start growing my own vegetables throughout the year. It rains here a great deal so 9 months out of the year I would like to grow indoors.
1.The max wattage for the extension cord is 1650Watts so would I be safe if the bulbs combined wattage is under the specified amount? (do i use cfl watts or equivalent incandescent watts to determine?) I know this light design may not be the most efficient, but do you see any potential hazard? Too many lights for one socket?
will be using eight 23watts (100watt equivalent) in 7 y sockets and 1 outlet attached to one extension cord outgoing to a surge protector. Which will have another extension cord providing energy source for another one of these
2. I would really like to do a different setup, but I'm unsure how to wire properly. Is there a resource online one can point me too for simple wiring or is there a rule of thumb? (white to white?) Pretty much everything I need to know to avoid a hazardous situation. (amps, etc.)
These are my main question that will help me guide into building lighting systems for my garden. Thanks a bunch
nothandyman is offline   Reply With Quote
Old 04-22-2013, 10:31 PM   #2
Rewards Points: 13,724
Is this a joke?
Old 04-22-2013, 10:33 PM   #3
Originally Posted by joecaption View Post
Is this a joke?
no i feel bad for being here now
Old 04-22-2013, 10:33 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,354
Why would you use something that dodgy when you can buy
larger type CFL lamps ?
you can try 48 w or 105w CFL's.
much safer !
dmxtothemax is offline   Reply With Quote
Old 04-22-2013, 10:40 PM   #5
this is to much power then? super dangerous? how about 1 extension cord to 3 y sockets for a total of four lights? would this be safer? Thanks
Old 04-22-2013, 11:27 PM   #6
would something like this be safer?
Old 04-23-2013, 10:18 PM   #7
Just use ONE large CFL !
Forget the little ones,
I'am talking about the larger one's !
48w or 105w.
Old 04-23-2013, 11:33 PM   #8
Always learning...
fetzer85's Avatar
Rewards Points: 262
Without knowing the details of your setup, I would suggest getting a couple 4ft shop lights, something like this...
http://www.lowes.com/pd_420865-43921...ght&facetInfo=
They're fairly cheap and will spread the light much more evenly to your plants. That contraption in your picture, although creative, wouldn't be all that effective. You'd kind of be building a mini-sun w/ 8 CFL's placed so closely together. Thing is the sun is millions of miles away, not 3 or 4ft above your plants. If you have an outside garden and the one end of it is 20ft closer to the sun, it's an insignificant amount given how far away the sun is. If you place that space ship shaped light fixture above your plants you will probably waste a lot of light outwards and give more direct light to plants very close to the lights. If you use shop lights you can hang them very close to your seedlings - I'm talking 6in away - and when they start to sprout you can raise the height. Since the fluorescent bulbs stay relatively cool you can keep them very close to the plants w/o damaging them. This also focuses the light downward onto your plants which reduces waste.
Something like this - http://i13.photobucket.com/albums/a2...g/frank007.jpg
fetzer85 is offline   Reply With Quote
Old 04-24-2013, 05:36 AM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The problem with the OP's setup is that he may be exceeding the socket's wattage rating, depending on number, and types of lamps.
Old 04-24-2013, 07:03 AM   #10
Rewards Points: 1,296
Don't plants need "grow lights" when doing this? Not much of a green thumb so I don't really know for sure. Not sure if CFL's come as grow lights.
danpik is offline   Reply With Quote
Old 04-24-2013, 07:13 AM   #11
MarginallyQualified
Rewards Points: 2,464
Thanks a bunch
Basic answers:
http://hightimes.com/read/dummies-guide-growing
Old 04-24-2013, 07:42 AM   #12
Rewards Points: 1,456
Will you be able to smoke these "vegetables"?
mikegp is offline   Reply With Quote
Old 04-24-2013, 07:43 AM   #13
Rewards Points: 6,652
Growing vegetables, more like a grow-op.
Old 04-24-2013, 07:45 AM   #14
Yes, but usually it is a fluorescent fixture with "Grow bulbs", and it is usually to get the seeds to start, before you plant them outside.
Old 04-24-2013, 07:59 AM   #15
Use ACTUAL watts, rather than equivalent incandescent watts, for the purpose of energy use, amps, and extension cord ratings.
The only purpose of the incandecent equivalent watts if to offer a comparison of light output to incandescent. For example, a CFL that uses 23watts produces similar light output to an incandescent using 100watts. Actual power use by the CFL will be 23watts. Eight CFLs, each consuming 23watts, will use a total of 8x23...less than 200watts total. This sounds well within the rating of a single outlet and extension cord to me.
BTW, I like the idea of shop lights.
oberkc is offline   Reply With Quote
Two "simple" electrical questions... Toller Electrical 3 02-04-2013 05:32 PM
Electrical diagramming questions Texas Couple Electrical 21 12-05-2012 12:26 AM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
