Electrical For Disposal - Box Inside Of Cabinet? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-07-2008, 06:29 AM   #1
Rewards Points: 270
Electrical for disposal - box inside of cabinet?
My thought would be that there would be a small surface mount box inside of the base cabinet itself and the air actuator would plug into that and in turn the disposal into the actuator. I am running new MC 12/2 wire w/ separate green ground. What would be the proper way to have this pass through the wall, as well as through the base cabinet?
pcampbell is offline   Reply With Quote
Old 05-07-2008, 08:18 AM   #2
Registered User
Termite's Avatar
The most common installation is a metal box mounted in the base cabinet. The receptacle is typically a "half hot." One outlet is switched for the disposal (pressure in your case), and the other is always hot for the dishwasher.
Surface mounting in the base cabinet is just fine. Just be sure to bond the box with the green screw or clip to your equipment ground.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
Low Voltage Cabinet Lighting Recommendations BigJimmy Electrical 2 01-20-2008 01:01 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 10:59 PM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
