Old 03-10-2007, 02:43 PM   #1
electrical disconnect to water heater (help)
I was told by a inspector that i need to put a electrical disconnect to my electric water heater which is about 8 feet to the main breaker panel.
my house was built in june 2002. (texas)
thanks for all help
p1eddie is offline   Reply With Quote
Old 03-10-2007, 04:37 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Unless the water heater is isolated by a wall or in another room he is off his nut!
As long as you can see it from the appliance the breaker IS the disconnect.
Speedy Petey is online now   Reply With Quote
Old 03-10-2007, 04:56 PM   #3
It's in a closet in the garage with a door. Maybe I should remove the door?
Old 03-10-2007, 05:27 PM   #4
It's up to you, but in this case the inspector is right.
If it were me I would leave the door and add the disconnect. Although in Tx I doubt you are concerned with pipes freezing.
I use $10, 60 amp, "pull out" type disconnects for water heaters. The whole thing costs less than just a 30a two-pole toggle switch.
Old 03-10-2007, 09:37 PM   #5
so is there a indoor disconnect? Or should i just get the outdoor one like you would use for AC.
Old 03-11-2007, 09:06 AM   #6
There are other disconnects, but this one is by far the cheapest and easiest to install. It is also simple to use.
Old 03-11-2007, 10:18 AM   #7
Thanks For the Help Speedy. I will go to Loews today to see if they have the parts I Need.
(pull out type correct)
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
