-   -   electrical disconnect to water heater (help) (http://www.diychatroom.com/f18/electrical-disconnect-water-heater-help-7027/)
p1eddie 03-10-2007 01:43 PM
I was told by a inspector that i need to put a electrical disconnect to my electric water heater which is about 8 feet to the main breaker panel.
my house was built in june 2002. (texas)
thanks for all help
Speedy Petey 03-10-2007 03:37 PM
Unless the water heater is isolated by a wall or in another room he is off his nut!
As long as you can see it from the appliance the breaker IS the disconnect.
p1eddie 03-10-2007 03:56 PM
It's in a closet in the garage with a door. Maybe I should remove the door?
Speedy Petey 03-10-2007 04:27 PM
It's up to you, but in this case the inspector is right.
If it were me I would leave the door and add the disconnect. Although in Tx I doubt you are concerned with pipes freezing.
I use $10, 60 amp, "pull out" type disconnects for water heaters. The whole thing costs less than just a 30a two-pole toggle switch.
p1eddie 03-10-2007 08:37 PM
so is there a indoor disconnect? Or should i just get the outdoor one like you would use for AC.
Speedy Petey 03-11-2007 08:06 AM
There are other disconnects, but this one is by far the cheapest and easiest to install. It is also simple to use.
p1eddie 03-11-2007 09:18 AM
Thanks For the Help Speedy. I will go to Loews today to see if they have the parts I Need.
(pull out type correct)
