Electrical Diagram For 3 Way Switch And 3 Way Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 06:27 PM   #1
Retired and adjusting
Electrical diagram for 3 way switch and 3 way dimmer switch
I am installing 6 recessed ceiling lights in a basement. I have power going to the lights, then to the regular 3 way switch with 14/2 wire and then ran a 14/3 wire to the 3 way dimmer switch. I used the diagram below but the lights do not come on no matter which way I have them flipped. What wire(s) do I need to change to make this system work with this configuration? Thanks for any help you can provide me. I FAILED TO MENTION IN MY FIRST POSTING THAT I WILL BE RUNNING 6 CEILING LIGHTS. DOES THE WIRING FROM THE LIGHT FROM THE FIRST ONE RECEIVING POWER CHANGE IN ANY WAY OR JUST THE REGULAR BLACK/BLACK, WHITE/WHITE? DOES THIS MAKE A DIFFERENCE IN HOW THE WIRING FROM THE LAST LIGHT IN THE RUN GOES TO THE REGULAR 3 WAY SWITCH? SHOULD I TRY SWITCHING THE TWO POWER/TRAVELER WIRES AT THE 3 WAY DIMMER SWITCH?
I fixed the problem by running 14/3 wire between each light fixture. I had some pieces of 14/3 left over from other wiring projects and luckily did not have to buy any. THANK YOU VERY MUCH FOR YOUR HELP!!!!!!
Aurora65 is offline   Reply With Quote
Old 02-19-2013, 08:57 PM   #2
joed's Avatar
Rewards Points: 12,848
The diagram is correct. Either you wired different or maybe the dimmer is bad. Try the setup with a simple three way switch in place of the dimmer.
Old 02-20-2013, 04:38 AM   #3
I added some additional questions to make sure I have my wiring in order. Please look at my additional concerns and make any responses you feel are relevant.
Thanks for you help so far!!!!!
Old 02-20-2013, 08:08 AM   #4
joed's Avatar
Don't run the cable to the switches through the other fixtures. If you do that you need a four wire+ ground cable between the fixtures.
Just run a 2 wire cable from the one fixture to the additional fixtures connecting black to black and white to white.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Cannot Get New Dimmer Switch Working Correctly BzowK Electrical 8 02-11-2012 04:13 PM
wiring a digital dimmer switch albertlayden Electrical 8 01-27-2012 06:33 PM
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 02:39 PM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 12:25 PM
