Electrical In Detached Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 12:29 PM   #1
Electrical in detached garage
I recently bought a house that was built in 1951 that has a detached garage. When we were looking at the house the agent could never get a key to the garage however we could look inside through the windows. Now that I own the house and have the keys I noticed that there is no power in the garage. I have a light in the garage and a light on the top of the garage, outside the garage and neither works. I went inside the house and checked the breaker box and they are all fine. I have also checked the fuses in the house and they are fine too. My question is there separate fuses located in the garage that might have tripped? Does the electricity come from the house or is there a separate line? Does it vary per house or is there a normal wiring?
I sorry if this is so vague, I am a first time home owner just trying to figure out why the lights on and in the garage do not work but everything in the house works.
mattjub is offline   Reply With Quote
Old 04-06-2010, 05:23 PM   #2
Master Electrician
most likely it was dissconnected at some point for some unknown reason and never hooked back up again. It would involve alot of trouble shooting most likely to get the power back on.
The bigger question is...is this the reason the agent could "never get" the keys?
andrew79 is offline   Reply With Quote
Old 04-06-2010, 05:34 PM   #3
You need to try to find where the power enters the garage & where it leaves the house
Look for tripped GFCI outlets
Make sure all breakers are on & fuses are not burnt out
Is there anything labeled as power to garage ?
Old 04-06-2010, 06:20 PM   #4
joed's Avatar
Rewards Points: 12,016
Unless there is a meter on the garage the power came from the house. If the garage is not finished you should be able to trace the cables and see where it was fed into the garage. Perhaps it was overhead and came down in a storm, never to be replaced.
Old 04-07-2010, 03:10 AM   #5
Union Electrician
goose134's Avatar
I'm only going to say this because I recently saw Slingblade, but have you tried changing the bulbs?
goose134 is offline   Reply With Quote
Old 04-07-2010, 08:00 AM   #6
Rewards Points: 506
Awwratt, den...reckon...
jlmran is offline   Reply With Quote
Old 04-07-2010, 11:44 AM   #7
Rewards Points: 82
Best advice so far.
Concrete Footings for a Detached Garage??? canyonbc Building & Construction 76 11-17-2016 11:23 AM
Wiring Detached Garage for 220v welder 8N1949 Electrical 2 03-11-2010 09:47 AM
60 amp sub panel for a detached garage canyonbc Electrical 32 01-11-2010 12:53 PM
Insulation questions for new detached garage mpt1123 Building & Construction 2 03-01-2009 09:18 AM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 05:36 PM
