Electrical Cover Installation On Repaired Drywall - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 10:34 PM   #1
electrical cover installation on repaired drywall
how to replace electrical covers onrepaired drywalls with sunken suckets and plugs?
wlh000001 is offline   Reply With Quote
Old 08-21-2011, 10:47 PM   #2
how do you screw the cover to the sunken plug or sucket? Do you use longer screws?
Old 08-21-2011, 11:36 PM   #3
Licensed electrician
Rewards Points: 1,020
The box should be recessed no more than 1/4". Any deeper and a box extension would be required. Unless the setback was less than 1/8" I would use an extension to avoid the spongy mounting when plugging something in.
frenchelectrican (08-22-2011)
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Cover up unused electrical boxes? eastie Electrical 12 08-10-2009 08:42 PM
4x4" juntion box in 'leaky' location - no cover or romex connectors culturalenigma Electrical 9 07-29-2009 07:43 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
