Electrical Cord On A Air Conditioning Unit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 12:46 AM   #1
Electrical cord on a air conditioning unit
My dog chewed through my air conditioning units wire(while it was unplugged)... I have a replacement wire but the replacement wire has a white, black and a green wire... But on my ac unit the wires have three wires two with no colors and one green ( one side of the wire have black writing) ... Do I connect the black wire from the replacement wire to the side that have the black letters on the ac units cord and the white wire from the replacement cord to the other side???? Please help me the heat is a killer....
Jmarrero856 is offline   Reply With Quote
Old 09-02-2010, 02:00 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Is the replacement cord is the same size as the oringal cord and the type as well ??
Normally I will just follow that A/C manufacter to see if have excat replacement due the conductor size plus the rating of the cord that will affect it.
The aftermarket cord like you replace some may not work very well due the diffrent rating.
The oringal cord will have a marking or ribbed side that is netural while unmarked side is hot conductor unless you have 240 volt unit that can get little tricky.
Merci.
Marc
Old 09-02-2010, 06:50 AM   #3
Electrical Contractor
kbsparky's Avatar
...... Do I connect the black wire from the replacement wire to the side that have the black letters on the ac units cord and the white wire from the replacement cord to the other side???? ...
No, exactly the opposite. The white conductor connects to the same place as the original cord's half with the writing on it.
-KB
Deck Landing and A/C Unit Master Brian HVAC 10 07-22-2010 08:08 PM
Glacier on my AC Unit? Where's Al Gore? livinginthepark HVAC 10 07-13-2010 04:59 PM
Electrical issue - 240V - Water Heater emoore Electrical 9 09-30-2009 02:45 PM
Advise on installing tv display unit bookersbeauty Interior Decorating 2 04-23-2009 05:02 AM
Bryant Air Conditioning Unit ARTLEE HVAC 1 07-01-2007 08:22 AM
