Electrical Continuity Tool - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2006, 10:37 PM   #1
Rze
Average Joe
Rewards Points: 79
Electrical continuity Tool
Is there a electrical wire continuity tester on the market? OK, before you say....what an idiot, of course there is....I am not looking for a circuit continuity tester that you can do from one end with a lead on the Line and one on the Nuetral (or Ground). Rather if I want to make sure that I have the same wire on both ends. I know thare is a tester for coax that you put a "Cap" on one end and test from the other to ensure that it's the same cable on both ends. I have to think that there is an electrical wire equivelent since it would be a great tool for mapping your existing electric.
Thanks!
Rze
Rze is offline   Reply With Quote
Old 09-18-2006, 10:40 PM   #2
World famous jerk.
Yep. It's called an Ohm meter.
mdshunk is offline   Reply With Quote
Old 09-18-2006, 10:46 PM   #3
Rze
Average Joe
Rewards Points: 79
OK But...
Thanks, but I thought an Ohm meter tested resistance and had two leads that have to be used at the same end. Does an Ohm Meter have a "remote" end and meter end? All the meters I've seen do not.
Old 09-18-2006, 10:54 PM   #4
World famous jerk.
The "remote" would be a wire nut.
Us electricians call this "ringing out a circuit".
Old 09-18-2006, 10:56 PM   #5
Rze
Average Joe
Rewards Points: 79
OK...I'll have to experiment with this some and see how it works.
Thanks!
Old 09-19-2006, 05:11 AM   #6
Yes you can buy "cat and mouse" testers for electrical wires. They work by putting a tone on the line, and you use a reciever to find the wire on the other end. The ones that work on live circuits 120vac and up are not cheep.
A telephone tester will work on circuits that are de energized.
jwhite is offline   Reply With Quote
Old 09-19-2006, 07:06 AM   #7
I feel kind of stupid stating the obvious, but this is a DIY forum
rze
they are saying to tie two wires together at one end then go to the other end and see witch two now have continuity.
hurricaneflyer is offline   Reply With Quote
Old 09-19-2006, 09:17 AM   #8
I blame ProWallGuy
Rewards Points: 150
In all fairness, they did answer the poster's question. Its the not-too-old adage, "Garbage in, garbage out."
Double A is offline   Reply With Quote
Old 09-19-2006, 11:58 AM   #9
Is this for house wiring?
Turn off the circuit breaker and the outlets that are without power will be the wire.
redline is offline   Reply With Quote
Old 09-19-2006, 03:45 PM   #10
Double A, In all fairness, you are quoting rze out of context.
Mad Dog is goofing around with the rze and thats fine. I didn't say anything about it. I get a big kick out of his sense of humor. I just want to help the guy understand also.
Old 10-01-2006, 04:07 PM   #11
Electrical contractor
RobertWilber's Avatar
ya just need to fill those big tanks with inert material, see, and ....
RobertWilber is offline   Reply With Quote
Old 10-01-2006, 04:10 PM   #12
yeah, it can have a remote end
buy a spool of thhn, and unroll it to where you want your remote terminal point to be ...
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
I won't burn this luxury tool, right? KUIPORNG Remodeling 15 03-09-2007 03:11 PM
Is this Cutout Tool OK? ADKstorm Tools 3 01-24-2007 12:08 PM
