-   -   Electrical continuity Tool (http://www.diychatroom.com/f18/electrical-continuity-tool-3977/)
Rze 09-18-2006 10:37 PM
Is there a electrical wire continuity tester on the market? OK, before you say....what an idiot, of course there is....I am not looking for a circuit continuity tester that you can do from one end with a lead on the Line and one on the Nuetral (or Ground). Rather if I want to make sure that I have the same wire on both ends. I know thare is a tester for coax that you put a "Cap" on one end and test from the other to ensure that it's the same cable on both ends. I have to think that there is an electrical wire equivelent since it would be a great tool for mapping your existing electric.
Thanks!
Rze
mdshunk 09-18-2006 10:40 PM
Yep. It's called an Ohm meter.
Rze 09-18-2006 10:46 PM
OK But...
Thanks, but I thought an Ohm meter tested resistance and had two leads that have to be used at the same end. Does an Ohm Meter have a "remote" end and meter end? All the meters I've seen do not.
mdshunk 09-18-2006 10:54 PM
The "remote" would be a wire nut.
Us electricians call this "ringing out a circuit".
Rze 09-18-2006 10:56 PM
OK...I'll have to experiment with this some and see how it works.
Thanks!
jwhite 09-19-2006 05:11 AM
Yes you can buy "cat and mouse" testers for electrical wires. They work by putting a tone on the line, and you use a reciever to find the wire on the other end. The ones that work on live circuits 120vac and up are not cheep.
A telephone tester will work on circuits that are de energized.
hurricaneflyer 09-19-2006 07:06 AM
I feel kind of stupid stating the obvious, but this is a DIY forum
rze
they are saying to tie two wires together at one end then go to the other end and see witch two now have continuity.
Double A 09-19-2006 09:17 AM
In all fairness, they did answer the poster's question. Its the not-too-old adage, "Garbage in, garbage out."
redline 09-19-2006 11:58 AM
Is this for house wiring?
Turn off the circuit breaker and the outlets that are without power will be the wire.
:thumbup1:
hurricaneflyer 09-19-2006 03:45 PM
Double A, In all fairness, you are quoting rze out of context.
Mad Dog is goofing around with the rze and thats fine. I didn't say anything about it. I get a big kick out of his sense of humor. I just want to help the guy understand also.
RobertWilber 10-01-2006 04:07 PM
ya just need to fill those big tanks with inert material, see, and ....
RobertWilber 10-01-2006 04:10 PM
yeah, it can have a remote end
buy a spool of thhn, and unroll it to where you want your remote terminal point to be ...
