Electrical Connections Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 09:01 AM   #1
electrical connections question
I have a new lakefront home that has a wire stubbed into a junction box for "future dock lighting" in the crawl space. I am now connecting this to a GFI plug on the shore near the dock. My issue is that the wire stubbed into the box has 4 wires in it....red, black, white and plain copper. The wire heading out to the lake has three wires in it...black, white and plain copper. The wire in the box has "red to switch" and "black hot" written on it by the electrician who installed it. It is a weekend and I cannot get ahold of the electrician to ask him. Can you help me. I am thinking the dock lighting is supposed to be operated by two switches...one in the garage and one in the house. (3-way??) Thank you.
scottbu is offline   Reply With Quote
Old 08-19-2012, 09:37 AM   #2
Rewards Points: 1,014
You would know more about this than any of us, but black is probably constant hot, and red is fed from a switch
Anti-wingnut is offline   Reply With Quote
Old 08-19-2012, 10:00 AM   #3
Rewards Points: 6,652
That or it was possible that the run was originally meant for a 240vac sub panel, then someone changed their mind along the way.
Old 08-19-2012, 04:13 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I'm thinking black and white = constant hot. Red and white = switched controlled. Easily checked with a voltage tester.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-19-2012, 04:21 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,990
From the labels, it certainly sounds like the red wire is switched power for a light. You'd have to figure out where the switch is in your house! A three-way switch would be good, but you do not have enough wires to do that. You would need another wire to go between the switch in the house and the switch at the dock. There is a way you could still achieve the same result by using a relay, though.
mpoulton is offline   Reply With Quote
Old 08-19-2012, 09:35 PM   #6
" Euro " electrician
frenchelectrican's Avatar
I have done this before so therefore what the electrician did have two type of source one is switched ( the red wire that is controlled by a switch inside or outside of the house ) while second choice is constant hot which that mean unswitched source.
The reason why that electrician did that in first place in case you want unswitched at first but change the mind to switched verison or the otherway around so easy to do this real quick without tearing into the switch box inside the house.
But only sticky issue what the electrician done that part I do not know why but due he ran XX-2 conductor ( is this in the conduit or direct burial UF cable that will make the differnce ) if that was moi I just run in the conduit so can have it both way.
Merci,
Marc
Dishwasher Electrical Connections rathrboutside Electrical 1 03-28-2012 01:36 PM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Snowblower Electrical Question TimKLL Automotive Repairs 3 01-20-2011 07:10 PM
Cape Cod Electrical Question jordan83 Electrical 8 01-12-2011 05:59 PM
a question Mexico electrical question stanlam Electrical 2 02-01-2010 09:27 PM
