Electrical Conduit Do's & Don'ts - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 02:58 PM   #1
From a codes standpoint is it allowed to run electrical wire in a conduit when the conduit is in a wall? If so, what kind of conduit should I use for the electrical wire? I'd just like everything to be neat in the wall and will help me to keep organized. Thanks.
Also, what kind of wire should I use for kitchen wiring? Gauge, etc.
management is offline   Reply With Quote
Old 12-17-2011, 03:07 PM   #2
jproffer's Avatar
Rewards Points: 716
1) As unnecessary as it is, it's fine to do that.
2) EMT would be the smallest OD for the same ID, but any type you wish is fine.
3) 12. Kitchen countertop receptacles have to be 20amp
jproffer is offline   Reply With Quote
Old 12-17-2011, 03:43 PM   #3
Rewards Points: 2,240
Put the kitchen outlets on a "GFCI" protected circuit.
Separate from the "fridge", the lights, dish-washer, disposal, etc...
A suggestion.
rossfingal
rossfingal is offline   Reply With Quote
Old 12-17-2011, 03:50 PM   #4
A suggestion.
rossfingal
I was most definitely going to do that. Thank you. Please provide more suggestion. I'm very open to them.
Old 12-17-2011, 03:52 PM   #5
So I have to buy 20amp breakers as well? I thought they they came in 15amp. That's good to know.
Old 12-17-2011, 04:39 PM   #6
jproffer's Avatar
Rewards Points: 716
They come in 15's and 20's for "normal" 110 circuits (rec. and lighting)
Kitchen requires 20A
Bathroom is better off as 20A (hair dryers, etc) but I'm not sure if it's required.
It's been a while, but IIRC you can have recetacles from ALL bathrooms on one circuit....OR....you can put lights and receptacles from each bathroom on its own circuit, but each bathroom must be seperate. (someone do correct me if that's not right, or if it's "out-dated" info)
There are MANY more regulations regarding wiring a whole house, if that's what you're doing.
Old 12-17-2011, 04:45 PM   #7
Thanks very much for the info. I'm only looking to wire the kitchen now. I'm moving the location of the kitchen from the basement to the first floor. Odd layout in this old historic townhouse.
Old 12-17-2011, 04:49 PM   #8
jproffer's Avatar
Rewards Points: 716
When I said that the kitchen requires 20A, I should have been more clear (just read it again...sorry )
The countertop rec. require a 20A circuit and no other rec. may be on that circuit. The wall rec. can be 15A as far as I know. Fridge must be by itself.
Old 12-17-2011, 05:02 PM   #9
Rewards Points: 14,278
If you notice the person that keeps replying to your post is not an electrition and is only guessing at his replys.
There is no need for conduit in a residential home. Only in commercial.
In a kitchen you need 12-2 20 amps. GFI protected, no more then 4' apart for the outlets and 14-2 for the lights.
Microwave, ref, dishwasher should be on there own 20 amp. non GFI circuts.
Old 12-17-2011, 06:47 PM   #10
For clarification, the 14-2 can not be used in a 20 amp circuit, it is only rated to 15 amps
CaptainD51 is offline   Reply With Quote
Old 12-17-2011, 06:47 PM   #11
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
Some areas require conduit, but most do not.
If you are not required to use conduit, you can use nmb cable.
Where are you located?
jbfan is online now   Reply With Quote
Old 12-17-2011, 09:40 PM   #12
jproffer's Avatar
Rewards Points: 716
Which is why i said in my FIRST reply:
Just because I'm not an electrician doesn't mean I'm just blindly guessing.
OH, and also a microwave doesn't have to be on it's own circuit unless it's a built-in unit. A countertop microwave can just plug into the common circuit with everything else.
Old 12-17-2011, 09:49 PM   #13
Licensed electrician
Rewards Points: 1,864
The kitchen, dining and pantry areas receptacles are required to be on 20 amp circuits. No lighting allowed on these.
Old 12-17-2011, 09:51 PM   #14
Rewards Points: 760
It is required. The bathroom receptacles must be 20 amp, GFCI protected.
Correct.
AandPDan is offline   Reply With Quote
Old 12-17-2011, 10:37 PM   #15
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Just remember, no more than 360 degree worth of turns in a conduit run. You can add junction boxes to get more turns. The reason is mostly because with too many turns it just makes it hard, if impossible, to run new wire through it. The jboxes will provide a point to pull the wire and push it through the next run.
The Following User Says Thank You to Red Squirrel For This Useful Post:
plummen (12-18-2011)
Humming / vibration in electrical conduit codybear Electrical 4 10-26-2010 06:21 PM
Underground Conduit donnyc Electrical 1 09-20-2010 01:29 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Sealing conduit coming into house encased with waterline pacamaroman Plumbing 3 06-18-2009 08:48 AM
