Electrical Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 01:45 PM   #1
Electrical Conduit
I am trying to run some wire through some conduit outside. The problem is that the people before me snaked it and left in a metal wire. Then did nothing so the metal rusted and is now stuck in the conduit. It broke on both sides when trying to pull it out...
Any suggestions on how to remove this metal wire from within the conduit? So far I have tried a pressure washer, leaf blower, and a shop vac?
PoolManager is offline   Reply With Quote
Old 05-20-2013, 02:06 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Before giving any advice (you probably won't like it anyway), we are going to need either more info, or a picture ode this metal wire.
Old 05-20-2013, 02:15 PM   #3
The conduit was put in to run a speaker wire from the pool house to outdoor speakers. When it was installed (2 years ago), they snaked it and left a metal wire (like coat hanger thickness) inside so that it could be used to run the speaker wire through. No one touched it for two years and it wasn't sealed so water, dirt, mud got in there with the metal wire. When we went to pull it through the other day, it snapped on both ends. Leaving the entire middle piece still with the metal wire inside. The conduit design runs straight down about 6-8 inches, makes a 90 degree turn, runs for about 5 feet under cement, makes another 90 degree turn, then up 8 inches to the other side. It basically runs under a concrete walkway. So there is about 5 feet of this rusted metal wire stuck in there (I don't know how to take a great picture of it).
So far I tried pressure washing it out and I tried to use a snake to push it out. I am pretty sure I am SOL but I didn't know if there were any tricks to get a blockage out of conduit.
Old 05-20-2013, 02:30 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
What size conduit?
Old 05-20-2013, 02:41 PM   #5
I think it is 1 inch conduit.
Old 05-20-2013, 02:42 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,990
What kind of conduit? There may be some solutions to this.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 05-20-2013, 02:47 PM   #7
If the conduit is PVC and the steel wire is small, you could probably just fill up the conduit with muriatic (hydrochloric) acid and leave it for a week or so. Steel dissolves pretty quickly in hydrochloric acid, and PVC is unharmed.
Old 05-20-2013, 02:55 PM   #8
It is PVC and it is fairly small... Plus as a pool, I do have access to acid. Then after it dissolves just add water then suck out or blow out all the water/acid mix? The other thing I thought of was a plumbers snake and just try to pull it out.
Old 05-20-2013, 04:03 PM   #9
Rewards Points: 1,192
Get a metal fishtape and push it into coduit about 3 feet past the old fish line.Take your fishtape holder and start winding (rolling) it to snag line.See if you get lucky.
bobelectric is offline   Reply With Quote
Old 05-20-2013, 04:23 PM   #10
JW
mm11's Avatar
Rewards Points: 622
This works extremely well. That acid will eat the fishtape.
Wait for the acid to do it's job, then blow out the raceway with compressed air. Make sure to have a tight seal against the conduit with the air line, or else the acid will spray all over you.
Be careful at the other end.
The acid will fly out- I would definitely cover this end with something that allows the acid to come out but does not fly off also.
mm11 is offline   Reply With Quote
Old 05-20-2013, 05:48 PM   #11
Thank you for all the help... After 6 hours of work, I was able to use my snake to push the majority of the rusted line to the 90 degree bend in the pipe. Then using a plumbers snake, I was able to hook pieces of it and keep pulling them out until I could run a wire through.
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Humming / vibration in electrical conduit codybear Electrical 4 10-26-2010 06:21 PM
Underground Conduit donnyc Electrical 1 09-20-2010 01:29 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
