Electrical Code For Running Wiring For Pots Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 11:57 PM   #1
Rewards Points: 160
Electrical Code for running wiring for pots lights
In Canada here, wondering if I am able to tack electrical wire to the bottom of the joists to run pots lights (gonna have enough space with drop ceiling...or do I have to drill into the floor joists and then run the wiring?
Thanks!
hellothere123 is offline   Reply With Quote
Old 07-13-2011, 07:53 AM   #2
Local codes vary considerably and not even sure about Canada.
Old 07-14-2011, 09:45 AM   #3
i wouldn't tack to the bottom of the joists, its just more open to damage from screws etc... if you really want to clip instead of drill do it on the side of the joists. it needs to be clipped within a foot of every box and every 5 feet therafter. Honestly though, go buy a good 3/4 inch spade drill bit and you'll be done in no time. i find it faster than clipping and you can run multiple cables through the hole you drill.
MitNotrof is offline   Reply With Quote
Old 07-14-2011, 11:11 AM   #4
Agreed, just drill it (center of the joist please- look it up if you're not familiar!), it's not hard at all.
Minich is offline   Reply With Quote
Old 07-14-2011, 11:18 AM   #5
Just call me Andrew
Rewards Points: 1,020
In the US, it's perfectly fine to tack to the bottom of joists (without a running board) if you have a dropped ceiling. I'd do that rather than drilling holes.
Andrew
secutanudu is offline   Reply With Quote
Old 07-14-2011, 12:40 PM   #6
yes tacking to the bottom is fine with a drop ceiling, i was just thinking is there ALWAYS going to be a drop ceiling there. if its ever decided to put up gyp, there maybe be more work than necessary involved with possibly relocating cables.
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 11:19 AM
how many lights in a circuit as per code pedrito Electrical 10 10-03-2010 01:25 AM
Wiring receptacle > switch > motion sensor lights Van Home Electrical 11 08-10-2010 12:27 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
