Electrical Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 07:29 PM   #1
Rewards Points: 672
I am replacing my home range. When it was initially installed 15 years ago, it was hardwired. Do present day electrical codes require that a range be plugged, with a 3 or 4 prong cord, into an outlet or is still o.k. to hardwire the new range? I have received mixed advice. Thanks!
kennykenny is offline   Reply With Quote
Old 03-20-2011, 07:40 PM   #2
Electrical Contractor
kbsparky's Avatar
You can still hardwire it, or use a 3 or 4 wire receptacle. Depending on what type of wire feeds it will determine whether you can ground the new one through the neutral or not.
Have you looked at the hardwired connections yet?
Post a pic!
-KB
Old 03-20-2011, 07:49 PM   #3
Rewards Points: 672
Here is a picture of the connections
Old 03-20-2011, 08:09 PM   #4
kbsparky's Avatar
I don't see any bare ground wire there ... is there one cut off, or is the wire completely missing?
Look at the cable --- does it state on the outer jacket that there is a ground wire present?
-KB
Old 03-20-2011, 08:16 PM   #5
Rewards Points: 672
There does not appear to be any other wires. Nothing cut off. The outside of the jacket states, 8AWG/3 triangle wire and cable type NM-B 600 volts
What do you think?
Old 03-20-2011, 08:19 PM   #6
joed's Avatar
Rewards Points: 12,940
I think the ground is cut. NM-B cable should have a ground.
Old 03-20-2011, 08:24 PM   #7
Rewards Points: 672
So you think that if I cut back the plastic, there should be a ground wire?
Old 03-20-2011, 08:31 PM   #8
Rewards Points: 672
The owners manual of the new range states the neutral or ground wire(white cord) should be connected to the center terminal. So is the neutral grounding the range?
Old 03-20-2011, 08:33 PM   #9
Master Electrician
Rewards Points: 3,874
NM cable was available without a ground years ago.
brric is online now   Reply With Quote
Old 03-20-2011, 08:40 PM   #10
" Euro " electrician
frenchelectrican's Avatar
That look like older NM cable that came sans grounding conductor at all which it was used to be common quite few years back but not anymore the new one will come with grounding conductors nowdays.
Merci,
Marc
Old 03-20-2011, 08:44 PM   #11
From my understanding, a 4-wire system will have two hot 110v wires, 1 neutral, and a ground. A 3-wire system, which the op appears to have, will have two hot 110v wires, and 1 neutral. If your range requires the 4-wire system, you will need to run a new wire from your panel to your range. It should be fine to directly wire the range. Though, I used a plug on mine, which is nice, because I can slide the range out every few months to clean behind it.
suprvee is offline   Reply With Quote
Old 03-20-2011, 08:44 PM   #12
Rewards Points: 672
So am I safe direct wiring using the three wires that have?
Old 03-20-2011, 08:48 PM   #13
kbsparky's Avatar
Yes, if there is no bare ground wire present. Simply leave the neutral bonding jumper in place, and connect the white wire to the center terminal.
Your appliance will be grounded through the neutral wire, which is permitted in existing homes that were wired with non-grounding cable, such as you have.
-KB
Old 03-20-2011, 08:51 PM   #14
Rewards Points: 672
Is there benefits or drawbacks or not matter to use a three or four cord. The owners manual lists using a three or four wire power cord.
Old 03-20-2011, 10:24 PM   #15
joed's Avatar
The OP quoted the cable as being NM-B. Did they make NM-B cable with no ground? NM-B came into the code in 1985 I believe. It should have a ground.
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 09:43 AM
Old Electrical Box Insurance Question bailey35 Electrical 4 06-29-2010 01:58 PM
Ontario Canada Electrical Code Question?!? njchan Electrical 4 05-10-2010 08:29 PM
Electrical Panel "cut-in" question Todd-sta Electrical 52 12-03-2008 11:07 PM
