Electrical Code On Panels - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 06:57 PM   #1
electrical code on panels
I have 3 empty spaces on my panel or do I have sub panel, and if so what is the amps for it.
deresti64 is offline   Reply With Quote
Old 09-30-2011, 06:59 PM   #2
Rewards Points: 150
Going to need more info, maybe a pic.
OhioHomeDoctor is offline   Reply With Quote
Old 09-30-2011, 07:08 PM   #3
I don't have a camera but it's a 100 amp federal pioneer panel, need to add 3 more 15 amp breakers.
Old 09-30-2011, 07:17 PM   #4
Missouri Bound's Avatar
Do you mean Federal Pacific? If so, consider changing that panel first.
Old 09-30-2011, 07:21 PM   #5
no federal pioneer,stab-lock,panel is 1 year old
Old 09-30-2011, 07:25 PM   #6
In order to know what you have available, you need to do a load calculation. What is the amperage of your service? Are major appliances gas or electric? And Federal Pioneer appears to be made by Federal Pacific. Not sure if I would have either.Federal Pacific Electric FPE Stab-Lok Panel Circuit Breaker Hazard, Repairs, E
Old 09-30-2011, 07:45 PM   #7
Master Electrician
Rewards Points: 3,866
Are you in Canada?
brric is online now   Reply With Quote
Old 09-30-2011, 07:46 PM   #8
Rewards Points: 150
Install tandem breakers.
Old 09-30-2011, 07:48 PM   #9
Licensed electrician
Rewards Points: 1,608
You need to add 3 breakers and you have 3 empty spaces. You can add a sub panel later if needed.
Old 09-30-2011, 07:57 PM   #10
Electrical Contractor
kbsparky's Avatar
Federal Pioneer panels are sold in Canada. You can get `em at the home-horror stores right from stock.
The breakers are interchangeable with the old FPE breakers as well.
Interesting note is that the main breakers are the Square D type QOM in the newer panels.
-KB
Old 09-30-2011, 08:53 PM   #11
Electrician
Rewards Points: 794
Federal Pioneer, also known as stab lock is made by schneider which also makes Square D so I would not be suprised if some of the manufactuering is shared between the two.
To the OP, add 3 breakers and if you need a subpanel in the future, then you may need to consider a subpanel.
darren is offline   Reply With Quote
Old 09-30-2011, 10:49 PM   #12
thanks for the help,and yes I'm in Canada.
Old 10-01-2011, 11:11 AM   #13
Not all panels are listed for use with tandem breakers.
Old 10-01-2011, 12:00 PM   #14
Electrician
Rewards Points: 794
To add to what jim said there is no such thing as a tandem for a federal breaker, they use all the slim breakers until you get into the 2P60A breaker.
To the op be careful where you stick your breakers if you are useing a 240V breaker or a multiwire branch circuit. It is very easy to put these on the same phase and not realize what you did.
Electrical Code in Chicago!?! moose186 Electrical 37 12-28-2014 12:27 PM
Where to find an online electrical code for Ontario? Red Squirrel Electrical 14 06-26-2014 06:43 AM
electrical code tradtke Electrical 6 08-02-2011 11:11 AM
Electrical Code Question kennykenny Electrical 14 03-20-2011 10:24 PM
Electrical Wiring code - through Studs? mike6679 Electrical 7 08-11-2010 08:16 AM
