#1 |
Veteran Newbie
Electrical circuits in 'wet room' bath
I am working on designing an accessible bath in my basement, set up as a 'wet room' (tile everywhere, sloping floor to open shower in corner). What are the unique NEC electrical considerations, specifically with regards to outlets (as I suppose shower lights and a switch exterior to the room will suffice). The only 'wet room' stuff Google shows me is about the UK and Plan P, etc.
Thanks! |
#2 |
You talking to me?
well, any devices or appliances installed in the room would have to be rated for wet conditions and depending where they are, maybe even waterproof.
#3 |
Veteran Newbie
No permanent electrical appliances, just need lighting and the code required outlet. Just curious how to handle that with an open air shower.
#4 |
Licensed electrician
The roll in shower I have seen still had sidewalls and a shower curtain to contain the spray.
I did not wire this any differently than any other bathroom.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| The Following User Says Thank You to Jim Port For This Useful Post: | catmandu (03-02-2011) |
#5 |
Veteran Newbie
Thanks, that's good to know, I'll press forward with a logical design.
#6 |
Super Moderator
There are several good threads over in Contractor talk--Kitchen and Bath--
The forum is for contractors only,but you can look and read. Roll in showers are a frequent topic. ---Mike---Contractor Talk - Professional Construction and Remodeling Forum
New members: Adding your location to your profile helps in many ways.--M-- |
| Display Modes | |
| Room Air Purifier - which is best? | nhart | Appliances | 16 | 12-07-2012 07:00 AM |
| Well Room (Cold Room) Issue--Advice Needed | TomPgh | Building & Construction | 11 | 01-03-2011 07:31 PM |
| Vents from boiler room | RammsteinNicCage | HVAC | 3 | 03-11-2009 08:28 PM |
| bath room tiling question, laying tile around a curve | everyman | Kitchen & Bath Remodeling | 2 | 02-14-2009 02:21 PM |
| Bath room remodel subfloor removal | first-timer | Carpentry | 9 | 06-21-2007 03:11 PM |
