Electrical Circuit Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 02:13 PM   #1
Electrical Circuit installation
can i wire a drag cord directly into the circuit breaker?
BluJAE is offline   Reply With Quote
Old 08-10-2012, 02:50 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
I guess you mean a drop cord, and the answer is no.
Old 08-10-2012, 03:14 PM   #3
yeah, just a regular 15 amp extension cord, wired in as if it were a single outlet, why not?
Old 08-10-2012, 03:23 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
National Electric Code.
Wire a GFCI receptacle next to the breaker box and plug your cord into it.
Coastal South Carolina
Old 08-10-2012, 03:33 PM   #5
Is the GFCI really necessary? I know my idea is out of code, but I want to know if it is actually dangerous or not, and why. I am renting the basement where I live, and all the outlets here are on 1 ungrounded circuit, I want more circuits without having to do a lot of cutting or drilling. To my limited knowledge, a 15 amp heavy duty extension cord has all the same thermal and electrical properties as residential electrical wire.
Old 08-10-2012, 04:05 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Tell your land lord you need more electrical requirements.
Old 08-10-2012, 04:09 PM   #7
Rewards Points: 133
National Electric Code was written for a reason.
You said it yourself you have limited knowledge. And what you want to do is mess with the main panel, which can have all sorts of disastrous effects if you hook it up wrong, whether it be you shocking yourself to death just opening the panel, or trying to install the wiring, to possibly burning it down if you don't correctly wire it.
And even though the Cord may be rated for 15 amps, it isn't rated the same as actual electrical cord.
Either get an electrician to install another box, talk to your landlord about having it done, or stick with what you have
jimmyfloyd is offline   Reply With Quote
Old 08-10-2012, 04:15 PM   #8
Missouri Bound's Avatar
Why don't you just wire an outlet?
Do you want it your way or the right way?
MIG Welder Electrical Supply Circuit Specs exciterfan Electrical 26 07-10-2012 05:15 PM
Electrical Circuit Fix travholl Electrical 1 11-11-2011 03:18 PM
electrical circuit darr Electrical 4 01-19-2011 07:45 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
residential electrical installation dallas520 Electrical 1 05-15-2005 08:51 AM
