Old 04-07-2012, 03:22 PM   #1
electrical circuit in a garage
Is their a minimum height for an electrical run in a garage. The outlets are mounted at 45 inches. But the main feed coming from the main panel is run out the bottom of the panel and is fed through the wall studs across the back wall at 21 inches above the garage floor.
acs4mkt is offline   Reply With Quote
Old 04-07-2012, 03:29 PM   #2
the Musigician
DangerMouse's Avatar
None that I know of.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-07-2012, 03:45 PM   #3
Semi-Pro Electro-Geek
If you're referring to the service entrance cable, then I would not be comfortable with that installation unless the cable is protected by a fused disconnect outside (in which case it's a feeder, not the service entrance). Service entrance cables must be protected from physical damage. What you describe is not adequately protected. If the service entrance cable gets damaged and shorts, the results are pretty spectacular - and very bad for your house.
Or when you say "main feed", are you just talking about the circuit for the receptacles? In that case it's still not generally accepted to run NM cable exposed in a garage below about 8' without protection, but it's much less of a big deal.
mpoulton is offline   Reply With Quote
RV circuit in my garage bmarkwell Electrical 34 09-14-2011 08:51 PM
Old Bathroom - all electrical on one circuit? how to change? Steve19 Electrical 16 03-14-2011 10:32 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Garage Electrical Wiring stickwagon Electrical 1 10-16-2010 12:16 PM
Circuit Problems - Garage DisturbedPanda Electrical 9 08-03-2007 10:23 PM
