Electrical Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 07:56 PM   #1
Opp
Electrical circuit
4 outlets in one room just quit at the same time, 2 outlets each on 2 different fuses (after 16 yrs of no problems). One of the circuits includes a ceiling light which works. A voltage tester shows there IS power to all the outlets. I changed all the outlets to new but no joy.
A tester shows one circuit has one good outlet & one hot ground reverse outlet (the circuit w/ the working ceiling light). The other circuit gives no reading from either outlet (but voltage tester says there's power). Any ideas???
Opp is offline   Reply With Quote
Old 12-15-2011, 09:00 PM   #2
Check out the still working outlets right next to these.
Billy_Bob is offline   Reply With Quote
Old 12-15-2011, 09:02 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,102
You have mosy likely lost the neutral side,
to that circuit/branch.
That would explain the hot reading.
dmxtothemax is offline   Reply With Quote
Old 12-15-2011, 09:03 PM   #4
joed's Avatar
Rewards Points: 12,000
Open neutral. All your readings are telling the neutral wire is open. Check the working devices on the circuit as well as the dead ones and the switches.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 03:40 PM
Electrical Circuit Doesn't Work kcrossley2 Electrical 11 05-21-2009 05:22 PM
Electrical weirdness jheavner Electrical 27 10-09-2008 06:40 PM
