Electrical ? Chint Contractor Cn1 Wire Diagram - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 12:40 PM   #1
jsk
Unhappy
electrical ? chint contractor cn1 wire diagram
have 4 wirers from switch 220 volt brown&black(plus) blue&gray(minus) ground(yel green)
brown+ blue- and ground yelgreen to pump
chint nc1-0910contactor 20 amps
top: side A1 and A2 push in holes plus in line 1/L1, 3/L2, 5/L3, 13 NO
botom side only A2 push in plus in line 2/T1, 4/T2, 6/T3,14 No
which wire goes in where?
jsk is offline   Reply With Quote
Old 11-03-2012, 06:13 AM   #2
DIY staff
Rewards Points: 7,174
What are you wiring?
Old 11-03-2012, 07:05 AM   #3
Rewards Points: 2,516
brown+ T1-L2/5L3
blue- 6/4S +2/DE
minus/plus H4@2DK + minus
wirers yelgreen + 2/T2--G/4X +2slope
does this makes sense???
hammerlane is offline   Reply With Quote
Old 11-04-2012, 01:39 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Are you in European area if so let us know I will post the correct connection sequine
For normal three phase supply the Brown et Black et Grey ( Readers don't scream on this one and it is legit over here in European side ) The bleu is always netural over here
Is your motour is single phase or three phase that will make the differnce on the connection at the contractor.
Merci,
Marc
Trying to understand basic electrical concepts, how was this possible? Kevin993 Electrical 13 04-11-2016 09:04 PM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Cap electrical wire? oscarMadison Electrical 5 03-01-2009 09:26 PM
dishwasher electrical wire feb Electrical 31 04-12-2008 10:04 AM
sliced electrical wire farrington135 Electrical 1 02-08-2006 05:18 PM
