Electrical Chase - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 06:54 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Electrical Chase
My first plan was to run all the electrical to the 2nd floor (2 story house) together in a chase in the middle of the house. Now I'm looking at my open walls and thinking it would be a lot less wire if I run 2 or 3 separate chases up the exterior walls to the 3 bedrooms and bath. Total of about 5 circuits at most.
Is there any reason I should not do this?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-27-2011, 07:07 PM   #2
Code05's Avatar
Rewards Points: 1,104
No, code wise it is legal. A sub panel in the attic may be more efficient.
Code05 is offline   Reply With Quote
Old 09-27-2011, 07:10 PM   #3
I have gas!
Thanks, sub-panel is not an option because the attic isn't easily accessible.
Old 09-27-2011, 07:25 PM   #4
I have gas!
One other question, is a 3/4" hole sufficient for 2-12/2 wires?
Old 09-27-2011, 07:26 PM   #5
Licensed electrician
Rewards Points: 1,766
A 3/4 hole will be fine for 2 12-2 cables.
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
