-   -   Electrical Channel (http://www.diychatroom.com/f18/electrical-channel-35442/)
tranman 01-08-2009 02:13 PM
Electrical Channel
I'm thinking about installing two florescent, surface-mounted lights in my garage on the ceiling. Instead of cutting up the wallboard that is already installed on the ceiling, I was thinking about using the raceway metal channel designed exactly for that use. Both fixtures would tie in to the existing outlet in the ceiling and the two fixtures have a side hole that the wiring would come out of and into the channel. My question is: how do you tie the wiring into the existing outlet in the ceiling when the wiring will be outside of outlet cover (flush to the ceiling)? Do you drill a hole in the wallboard new to the outlet and bring it into the box that way or something else?
jerryh3 01-08-2009 02:18 PM
There are boxes that mount to the existing outlet and you can run the wiremold out of those. I'll try to find a link in a few minutes.
rgsgww 01-08-2009 02:23 PM
I would get a box extension like this
http://electrical.hardwarestore.com/...on-601947.aspx
and run conduit to the lights.
Since you want to use raceway,
http://www.grainger.com/Grainger/items/3YY65
and the raceway would be
http://www.grainger.com/Grainger/items/3YE30
Secure it with something like this
http://www.grainger.com/Grainger/items/3YY45
Where does the wire feed into the fixtures? back or sides?
tranman 01-08-2009 08:56 PM
Good idea
Had not thought about lowering the outlet to match the others. Thanks!:thumbsup:
