Electrical Challenge! Can YOU Solve It? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-03-2009, 10:06 PM   #16
Originally Posted by Codywookman View Post
Your LEDs @12v will each need a dropping resistor. (12-2)v/.02 = 510 Ω at 1/4 w or 1/2 w.
You have a link to your 120 vac LEDs?
Old 09-04-2009, 10:37 AM   #17
OUCHTHATHURT
Is it worth getting new LEDs with built in resistors?
What do you think about the 24VAC thermostat running a 12VDC circuit?
Codywookman is offline   Reply With Quote
Old 09-04-2009, 12:27 PM   #18
Dunno' current prices on LEDs with integral resistors.
I'd think a 24 vac t'stat might take 24 vdc depending on its gizzards. I doubt the manuf. will give you an internal schematic so you can check it.
Can you post a prelim. system schematic? This sounds kind of muddled to me.
You should have the whole design fleshed out before you buy a single part. If you have some parts already the other parts may to be have changed to accommodate what you have so far. This kind of gets into when you're standing in Radio Shack with a calculator designing the thing while you're buying available parts. If you do that you can paint yourself into a corner because the last part is "unavailable" or made from unobtainium. Then you get to do the whole thing over again.
To avoid this you want to do "top-down design", going from the abstract to the literal. The last thing you write is the parts list.
This is for a working design. For a minimum cost working design you need component prices.
Old 09-05-2009, 03:51 PM   #19
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if the t-stat is an electronic stat, it is going to require 24 volt power or whatever it is specifically rated for.. If it is merely a mechanical t-stat that is rated to be used on a 24 volt control, then it will also work on a 12 volt control system.
Tags
cooling , electrical wiring , relay , thermostat
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
