Electrical/burnt And Melted Rubber Dryer Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 12:40 PM   #1
electrical/burnt and melted rubber dryer plug
When I removed 3 prong plug from receptacle at wall, I discovered that the plastic receptacle has ash and dirt in the back, and the 3 pronged plug was burnt and a portion of the rubber plug was melted. Anyone know why...should the plastic receptacle box be replaced with new plug . Can I do this or should I get an electrician? btw I did turn off dryer breaker first...Thanks!
rwiegel is offline   Reply With Quote
Old 02-10-2013, 01:10 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Bad connection caused something to heat up if you are not comfortable looking into it then it would be best to contact a qualified electrician.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-10-2013, 01:13 PM   #3
Rewards Points: 14,014
That or undersized wiring was used.
Old 02-10-2013, 01:27 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by rwiegel View Post
...and the 3 pronged plug was burnt
Anyone know why...
Could be lots of things.
Do you have a new dryer?
Should the plastic receptacle box be replaced with new plug?
Yes.
Can I do this...?
Probably.
Old 02-10-2013, 02:12 PM   #5
Retired
I’ve replaced these many times and it’s never been because of undersized wire. It’s usually because of poor fitting plugs or the wire is not tight in the terminals. I just don’t know how many I’ve found with loose terminals.
I think aluminum wire is pretty much a thing of the past, but there may still be some out there. I used to have to replace that as well because people just don’t understand that aluminum wire has to have terminals rated for it and it has to have cooling paste on it.
Once I found that the dryer did not have a vent pipe to take the hot air away and it was blowing right on the plug. Another time it was because the owner was in the habit of unplugging everything and the plug just could not take all the pulling.
I don’t like plugs being installed right behind the dryer and when I install them I try to put them above the dryer so they can be observed. Something people just don’t like the looks of them so I’ll put them just below the dryer top so at lest they are cool and accessible.
JohnnyB60 is offline   Reply With Quote
Old 02-10-2013, 02:23 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Loose connection in one of the receptacle box connectors for current carrying wire. Not quite as common as with range receptacles but happens due to cramped quarters and difficulty getting the wires connected properly with stiff wire in a close quarters flush mount box. Possibly DIY installed and not being assertive enough ... or too shallow of flush mount box causing wire to come loose mashing the wires into the box when fastening the receptacle. Or just loose in surface mount receptacle. These type can be a little tricky.
Undersized wire is a problem but will not cause this type problem ... won't matter the size of wire in a loose connection ... they all get glowing red...
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-10-2013, 03:44 PM   #7
Electrical Enthusiast
Rewards Points: 504
Might want to double-check for aluminum wiring, just in case.
Kyle_in_rure is offline   Reply With Quote
Old 02-10-2013, 04:20 PM   #8
Rewards Points: 1,538
Note that it is possible for the loose connection can be in the power plug (cord cap) and the receptacle (wall plug) melts first. Or vice versa. (This simply depends on the melting points of the plastic and rubber materials involved.
I have seen instances where most of the strands of wire have broken where they are attached to the prongs of a power plug, and the remaining strands get hot because they are too thin for the number of amperes, even over a distance of about a quarter inch.
Old 02-10-2013, 10:01 PM   #9
dmxtothemax's Avatar
Rewards Points: 5,504
Replace both the outlet and the plug with good quality,
heavy duty if possable.
Burnt plugs/outlets are usually caused by poor contact,
so could be either one.
Check that the wires are clean where they contact the outlet.
dmxtothemax is offline   Reply With Quote
DRYER HELP or Bigger Problem? SitEatChat Electrical 19 05-05-2012 01:12 AM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
Testing 220Volt Dryer Plug BCanuck Electrical 12 03-21-2011 07:56 PM
dryer problems grasshopper Appliances 3 09-23-2009 09:49 AM
