Electrical Breaker To Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 03:28 PM   #1
electrical breaker to switch?
i am installing new wiring on and i am in need of help if i am wrong. the power goes from the breaker to tghe switch which will give power to the ligh once it is connected? and do i have to do a pig tail to coneect the other bed rooms switches or would i go from power to switch then pig tail to the other switches in the beddrooms?
jaycantu78363 is offline   Reply With Quote
Old 01-21-2012, 03:32 PM   #2
Julius793's Avatar
Can you please explain I have no clue what you are asking
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-21-2012, 04:29 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I know this is a DIY site but if you have to ask that question (and the terms in which you ask it), you should not undertake electrical work. Hire an electricain or at least find a knowledgeable friend.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Speedy Petey (01-21-2012)
Old 01-21-2012, 07:44 PM   #4
joed's Avatar
Rewards Points: 12,002
If there is more than one light switch in the box then pigtail is one option to get power to the other switches.
Another option is to leave the hot wire long and strip out section of insulation. Wrap around screw and bring wire over to next switch.
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 01:31 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
Switch trips Breaker pvrio Electrical 4 09-21-2008 05:53 PM
