Old 04-24-2012, 09:34 PM   #1
Electrical - breaker
The breaker kicks when I put on the element & oven of the kitchen stove. It is a 40 breaker. What could cause the breaker to kick? Thanks!
acannavi is offline   Reply With Quote
Old 04-24-2012, 09:36 PM   #2
Electrical Contractor
Something wrong with the oven!
Have you used them together before without any problems?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-24-2012, 09:52 PM   #3
If this combo has worked fine before, then it is a shorted element or wire touching the frame somewhere.
Jeeps is offline   Reply With Quote
Old 04-24-2012, 11:54 PM   #4
Is it just a standard circuit breaker ?
Or is it a GFCI ?
Do both of the elements work fine, when on there own ?
dmxtothemax is offline   Reply With Quote
Breaker Box Ground/Neutral Connection Help SALEEN961 Electrical 23 10-17-2011 07:20 PM
Room loses electrical, circuit breaker not tripped Wnt2bsleepin Electrical 11 09-07-2011 06:47 PM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 07:27 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 11:13 PM
