Electrical Boxes In Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 08:13 PM   #1
Rewards Points: 150
Electrical boxes in attic
I have several junction boxes in the attic. The attic has loose cellulose insulation and it is quite dusty and dirty up there. Should the boxes be exposed and all insulation cleared from around the boxes?
Cossack is offline   Reply With Quote
Old 02-26-2008, 09:15 PM   #2
electrical contractor
Rewards Points: 150
I would think as long as they have tops on them they should be alright. Celulose insulation is treated with a fire retardent so it is not supposed to burn. The junction boxes should never get hot enough to start a fire anyway.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-26-2008, 09:18 PM   #3
Res Ipsa Loquitur
The boxes will not be affected by the dust in the attic. They should probably be kept visible as practical so they don't get "lost" under any insulation. They do not generate heat like a recessed light fixture would.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-26-2008, 09:26 PM   #4
Union Electrician
goose134's Avatar
A buddy of mine had the a good idea for marking the junction boxes. Before the insulation went in, he put little flags near all the boxes so they stick out past in insulation. The flags were like the kind used for marking underground gas lines and such.
goose134 is offline   Reply With Quote
Old 02-27-2008, 02:34 AM   #5
Sparrky
kingsmurf
EEEEEEEEEEEEEEEEEEEEEEEEEE
my least favorite insulation to find in an attic I must work in . .respirator and goggle work.....yuck
newspaper treated with boric acid I believe . .NOT good to breathe . .
and the old stuff cannot be trusted to be thoroughly treated . .so if you have any qualms whatsoever . .go to the big box store get a rol of FOIL TAPE . .like duct tape but thin metal . .and wrap those puppies . . .end of threat by fire . .now as to whatsi n the boxes as an fire hazard remains to be seen
Kingsmurf is offline   Reply With Quote
Old 02-27-2008, 05:34 AM   #6
When is fishing season?
CowboyAndy's Avatar
That is exactly waht I was thinking right before I read that.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 02-27-2008, 02:08 PM   #7
Rewards Points: 150
Thanks all for some great ideas. The house was built in 1863 so its anyone's guess as to when the cellulose was put in and if it is treated. I will do the flags and the foil tape.
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 05:08 PM
grounding electrical boxes handifoot Electrical 5 05-07-2006 11:40 AM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
