Old 10-11-2010, 05:01 PM   #1
electrical boxes
Is a seperate wire needed or does code call for a grd wire from the plug to the back of the box ?
Baldeegel is offline   Reply With Quote
Old 10-11-2010, 05:46 PM   #2
nap
You talking to me?
nap's Avatar
electrical boxes
I presume this is a metal box (if it wasn't, it wouldn't make any sense to connect a ground wire to the box). So, if the receptacle is of a self grounding type, you would not have to make such a wire connection. If it isn't self grounding, you must have a wire from the ground connection on the recep to the egc within the box.
fitting electrical wires to back boxes 1st fix Minimin Off Topic 2 05-03-2010 05:38 PM
Installing electrical boxes MikeyP Electrical 4 07-26-2009 10:32 AM
Air Sealing of Electrical Boxes on exterior walls PerpetuallyRepairing Electrical 6 07-14-2009 09:38 AM
Blue electrical boxes are to far in the drywall smblank3 Drywall & Plaster 3 05-19-2009 12:37 AM
Electrical boxes in attic Cossack Electrical 6 02-27-2008 03:08 PM
