Electrical Box Is Stripped - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 11:32 AM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
That hole is so large you might be able to install a 1/4" plastic, hollow wall anchor in there.
Something like....
Old 04-07-2012, 11:36 AM   #17
Another shot
Another shot showing where screw is just not catching. Can see where I tried wood filler.
Mgoody is offline   Reply With Quote
Old 04-08-2012, 12:27 AM   #18
dmxtothemax's Avatar
Rewards Points: 5,498
Short of replacing the j box with a metal one !
Have you tried using something harder than wood filler ?
Have you tried liquid metal ?
Its a metal / epoxy compound used for fixing pin holes
in metal automotive fuel tanks ?
Fit it, and let it set overnight.
Drill it for a hole.
Should work, if you dont overtighten it !
Sounds like a lot of work,
I would just bite the bullet,
and fit a new j box.
dmxtothemax is offline   Reply With Quote
Old 04-08-2012, 01:39 AM   #19
" Euro " electrician
frenchelectrican's Avatar
The most easy way to do this is just replace the junction box and what type materal is that on the wall if drywall it have to be be flush or a hair inside the drywall but not all way that far.
The smart box is next best item you can have not all big box store will stock this but I know it will getting more common nowdays due it used for both new work and old work methold.
Merci,
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
Hardway (02-24-2013), PaliBob (04-08-2012)
Old 04-08-2012, 06:01 AM   #20
Rewards Points: 1,192
Use an arlington One box.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
Old 04-08-2012, 12:03 PM   #21
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Info on replacement boxes:
Smart Box:http://www.smartboxinc.com/smartboxes.php
down load the PDF on single gang boxes
Arlington One-Box http://ecmweb.com/product_year/electric_box_occasions/
To find either box in your area you won't find it at HD, go to a local Electrical supply house that sells to Electricians. Check the Yellow pages or ask around.
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
frenchelectrican (04-10-2012)
Old 04-08-2012, 03:47 PM   #22
it looks as though you the plug is in a tiled wall. Is it possible to knock out the mortar around the top of the box where the screw would screw into.
I have found that a good easy and cheap solution when this happens it to take a piece of ground wire, and wrap it around where the screw would go and then wrap it around the top of the plug below the ears of the plug and twist the wire together with linesmans (or needle nose) until you hold the plug tight against the box. The other screw on the bottom of the box will keep the plug from moving around.
Cut off the excess wire to allow the plate to fit over the plug.
I'd be cautious to will the broken screw hole with anything that will not allow you to remove the screw and work on the plug in the future.
Hope this helps.
Swan is offline   Reply With Quote
Old 04-08-2012, 04:19 PM   #23
Ravenworks's Avatar
Hope this helps.
That is not a safe or proper way to fix this,it is a hack way of doing it.
K-Buz had the answer it that doesn't work do as one poster said use some JB Weld on it
Ravenworks is offline   Reply With Quote
Old 02-23-2013, 11:57 PM   #24
Smile
Stripped electrical Box
Originally Posted by Mgoody View Post
I am in the process of replacing electrical outlets in my newly purchased home (wife wanted white instead of cream). In the process I have found several that have the hole where the screw goes into the electrical box broken not allowing me the screw the outlet into the box. Without having to replace the electrical box itself, is there a quick fix to be able to screw the outlet into the box?
I had the same problem and went through a lot of trouble changing out the plastic box. It was a lot of time and trouble.
Then someone told me about a G-Clip that you push onto the box and you are good to go! They can be found at G-clip.us
ernest boudreau is offline   Reply With Quote
Old 02-24-2013, 07:43 AM   #25
Rewards Points: 1,536
My choice, tap the hole for the next larger screw size (I think it's 8-32) and use new screws of that size.
Saves having to mar the drywall and pry out the old box.
If you simply force in a wood screw or a larger screw, you may crack the tab of the box where it screws in.
Oops, just saw the other example where the tab was already cracked away; retapping the hole won't work on that one.
Old 02-24-2013, 08:31 AM   #26
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would coat the screw in wax or soap fill the hole with epoxy and put the screw into the wet epoxy. When it hardens just remove the screw and you should be good to go.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-24-2013, 10:02 AM   #27
http://www.amazon.com/Klein-Tools-62...ords=klein+tap
Hardway is offline   Reply With Quote
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 10:49 AM
