Electrical Box Is Stripped - Electrical - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 10:41 PM   #1
Electrical box is stripped
I am in the process of replacing electrical outlets in my newly purchased home (wife wanted white instead of cream). In the process I have found several that have the hole where the screw goes into the electrical box broken not allowing me the screw the outlet into the box. Without having to replace the electrical box itself, is there a quick fix to be able to screw the outlet into the box?
Mgoody is offline   Reply With Quote
Old 04-06-2012, 10:43 PM   #2
Rewards Points: 6,652
Get bigger screws, or get a tap set that is small enough to retap the screw hole.
Old 04-06-2012, 10:46 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Old 04-07-2012, 12:02 AM   #4
dmxtothemax's Avatar
Rewards Points: 5,600
If the problem is no threads in j box,
then you can use these -
http://i883.photobucket.com/albums/a...holdennuts.jpg
You can get smaller versions,
but this is the quickest picture I could find.
Auto motive stores should have them.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Mgoody (04-07-2012)
Old 04-07-2012, 12:05 AM   #5
k_buz's Avatar
Post a picture of one of the affected boxes?
Old 04-07-2012, 12:31 AM   #6
Licensed electrician
Rewards Points: 1,872
JB weld in the holes, or wood filler will give the screws something to grip.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Mgoody (04-07-2012), Ravenworks (04-07-2012)
Old 04-07-2012, 02:30 AM   #7
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The Pic was too small- Here is a X4 Blowup
That Pic was from an Australian Site
The pictured clips are referred to as Tinnerman Nuts
I used them in my first post-HS job as a trainee aircraft Electrician
http://www.cfi1.com/nuts-steel-sprin...9_17-l-en.html
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
Mgoody (04-07-2012)
Old 04-07-2012, 03:01 AM   #8
Tool Geek
PaliBob's Avatar
Here is a US supplier for 632 spring steel nuts.
Can save a lot of aggravation on stripped boxes.
$14.02/100
Available at Fastenal:
http://www.fastenal.com/web/products...0147953&ucst=t
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-07-2012, 04:26 AM   #9
Rewards Points: 1,192
Reread the op. Broken screws,not stripped.
bobelectric is offline   Reply With Quote
Old 04-07-2012, 06:31 AM   #10
Rewards Points: 826
Originally Posted by Mgoody View Post
...I have found several that have the hole (where the screw goes into the electrical box) broken not allowing me the screw the outlet into the box. ...
I'm not sure what a broken hole is. Stripped, plugged, missing, .....
It sounds more like a bar as in The Broken Hole....
I keep a 6-32 tap in the toolbox to clean up threads from time to time. Sometimes new boxes come with poorly formed threads and other times older boxes are cross threaded by the previous installer. A few turns with a tap and they are good to go. (I only use metal boxes, I don't use plastic as a personal choice)
curiousB is offline   Reply With Quote
Old 04-07-2012, 06:35 AM   #11
Licensed Pro
Define "hole... broken". Metal box or plastic?
Old 04-07-2012, 07:53 AM   #12
I=E/R
a7ecorsair's Avatar
Some brands of tan colored boxes have a metal insert at the screw holes. I've had some where the insert spins with the screw and some where the insert is stripped.
a7ecorsair is offline   Reply With Quote
Old 04-07-2012, 11:22 AM   #13
Sorry for the lack of more complete info. The box is plastic (grey, one of the older ones) and the plastic eyelet where the screw would fit into is broken (cracked or just plain broken off) not allowing the screw to catch onto anything. Tried wood filler but did not work.
Old 04-07-2012, 11:28 AM   #14
Here is a pic. You can see where I attempted to put wood filler to create a catch for the screw, but did not work.
Old 04-07-2012, 11:31 AM   #15
Plastic box. And the eyelet where the screw would go in to attach the outlet to the box is actually broken (therefore nothing for the screw to catch to).
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 10:49 AM
