Electrical Box Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 11:50 AM   #1
Bob Stellmacher
Electrical box requirements
I am adding 4 pendant lights over my kitchen counter. The room is already finished, so I need to add 4 round ceiling boxes. The pendants weigh maybe 3 pounds, so I was hoping I could use remodel boxes as securing to joists is not easily accomplished.
Alternatively, I can mount 1/2 inch deep pancake boxes to 3/4 x 4 x 18 in over ceiling drywall with center wire clamp. In both senarios, the fixture is hanging on drywall.
If neither of these options provide enough support, I could used 2x4's to span between the ceiling joists which are silent floor I-Beam style. A short spacer block on each side and screws through the drywall spacer block and support 2x4 would hold it in place. a 2 inch deep box can then be mounted to 2x4. This is obviously more work, but if the experts say it's needed, I will go that avenue.
Advice appreciated.
Bob
Atlanta Georgia.
stellmac is offline   Reply With Quote
Old 12-08-2011, 12:34 PM   #2
jproffer's Avatar
Rewards Points: 714
I don't think 3 pounds is going to pull through your drywall...assuming the drywall is as thick as it should be on a ceiling (5/8").
I say, fire-away with plan #1 (typical, everyday, remodel boxes)
jproffer is offline   Reply With Quote
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
What outdoor electrical is required in 2008 NEC? WillK Electrical 14 05-20-2011 08:04 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
