Electrical Box Recessed Too Far In Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2010, 05:06 PM   #1
Electrical Box Recessed Too Far in Wall
I have an outlet whose electrical box is recessed nearly an inch behind the drywall, thus when tightened to it, make it impossible to affix the coverplate as it is too far back. I guess i could locate a long screw for the coverplate, but that would look pretty stupid as there would be a large gap between the plate and the plugs. What else can i do? I think pulling out this elcetircal box and replacing is beyond me.
thanks
picsaro is offline   Reply With Quote
Old 01-23-2010, 05:14 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You can get a box extender like this from your local home store
wirenut1110 is offline   Reply With Quote
Old 01-24-2010, 09:17 AM   #3
Rewards Points: 1,494
If the box is not recessed too far back, like less than 1/4 inch, you can put washers under the tabs holding the receptacle unit and the receptacles can be brought close to the correct surface position.
The picture of the box extender above did not reproduce within five minutes of viewing ths page! It's a rectangular plastic ring that fits around the perimeter of the hole and comes in a choice of depths.
Old 01-24-2010, 03:26 PM   #4
i never knew that such a product existed! I hope to find it soon. Thank you very much for both replies.
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
how to find an electrical plug, covered up by a wall luckymen Electrical 15 07-07-2009 06:27 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
