Electrical Box Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2008, 08:37 PM   #1
electrical box question
posted this on the general forum too......
ok so i have another issue. i have two electrical boxes that have somehow been jammed about 1/2 to 2/3 of the way back, and i CANT get them back up, stuckon something and i dont want to tear drywall.
i have simply pulled the two outlets and wiring out of the box and it fits on the wall with just a longer screw. two questions:
a) is this fine or does it pose a serious hazard that wiring is outside the box and could touch the inside of the drywall where the box was cut
b) do they sell like a box extender? or could i wrap the hole in electrical tape to avoid hazard?
thanks
iminvalid is offline   Reply With Quote
Old 08-17-2008, 09:09 PM   #2
Rewards Points: 1,532
"that have somehow been jammed about 1/2 to 2/3 of the way back, and i CANT get them back up, stuckon something and i dont want to tear drywall." I don't understand I think: is this one box ganged together or two separate boxes? What kind of boxes did you use? I assume they are in a wall covered with drywall?
Overall, the outlets need to be completely in the box, which should sit flush with the finished wall, unless you surface mount the box. Maybe someone else understands the original post ( a picture would help).
bob22 is offline   Reply With Quote
Old 08-17-2008, 09:28 PM   #3
ya i moved into a place that has drywall over drywall
do they make electrical box extenders? its flush,just too far back
thanks
Old 08-17-2008, 09:42 PM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
Yes they do make extension sleeves for the box's they start at 1/4" and seen them as big as 1-1/4". any electrical store should have the.
yes you need them. BOB
Old 08-17-2008, 10:50 PM   #5
Licensed electrician
Rewards Points: 1,054
Try the Arlington BE1. Should be available at electrical supply houses.
Old 08-18-2008, 12:55 AM   #6
Cow
Yep, no big deal. Just use one of those^^^.
We call them arc shields or spark shields.
Cow is offline   Reply With Quote
Home Electrical / Car Stereo Question pjpjpjpj Electrical 4 08-12-2012 07:59 PM
electrical box question iminvalid General DIY Discussions 1 08-17-2008 09:18 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 04:33 PM
