Electrical Box Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2013, 03:24 PM   #1
I had to buy a blue PVC Carlon adjustable switch box. It is adjustable by moving the screw either in or out and it adjusts the depth of the box. My question is that it does not come with screws or nails to attach to stud. What should I use?
jspyke52 is offline   Reply With Quote
Old 08-03-2013, 03:40 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
The metal plate has screw holes in the top and bottom, and on the front. to mount it to the stud.
Old 08-03-2013, 03:41 PM   #3
Licensed electrician
Rewards Points: 1,612
Roofing nails, drywall screws.
Old 08-03-2013, 03:41 PM   #4
Yeap, what type of screw or nail should be used and length?
Old 08-03-2013, 04:02 PM   #5
Bill Kearney
Rewards Points: 1,174
Doesn't much matter, you're likely to have plenty o'drywall screws around, use those. 1-5/8" are the typical length for those.
But why are you going to use those boxes? Do you know you're going to have more than the typical 1/2"-5/8" of drywall on the wall in front of them? If not then save yourself the money and just use regular boxes.
wkearney99 is offline   Reply With Quote
Old 08-03-2013, 04:41 PM   #6
thanks, had to go with that since the studs r to close together
Old 08-03-2013, 05:09 PM   #7
Rewards Points: 4,796
Drywall screws aren't the best choice because of the countersunk head style. The screw can't countersink into metal, so the head will stick out, and tend the push the drywall out from the edge of the box a little - exactly what you're trying to avoid with the adjustable box. No major deal, but flat head nails work better.
jeffnc is offline   Reply With Quote
Old 08-03-2013, 07:20 PM   #8
Bill Kearney
Seems if you're using drywall thin enough to have that problem then you probably shouldn't need to use these boxes anyway. That and run 'em through the center of those mounting holes. But I certainly wouldn't argue against using nails.
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 04:49 PM
Electrical Panel question pattyobrien3 Electrical 19 09-14-2012 11:11 AM
vent hood electrical connection question cbendock Electrical 4 02-12-2011 10:33 PM
Cape Cod Electrical Question jordan83 Electrical 8 01-12-2011 05:59 PM
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 08:03 AM
