Electrical Box In My Garage. What Is It? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 11:43 PM   #1
Rewards Points: 452
electrical box in my garage. What is it?
There are two boxes in my garage which were installed by the previous owner, who was an electrician.
One is a circuit breaker box for garage electricals, and the one of the right is I dunno. It has a transformer block sticking out, so I can't make a cover for it. It just sits there exposed.
What is that transformer box for? Is it dangerous to leave it exposed like that?
Also, there is a twisted strand ground wire going from the bottom of the breaker box directly to the outside, into the dirt.
Is that dangerous to leave it exposed like that too?
electrical box in my garage. What is it?-img009.jpg   electrical box in my garage. What is it?-img014.jpg
pman6 is offline   Reply With Quote
Old 06-04-2013, 12:03 AM   #2
MarginallyQualified
Rewards Points: 2,464
It isn't idea and should be covered eventually...
but it'll wait a few days for you to find or make something.
Where do those wires lead? That'll tell the tale.
Old 06-04-2013, 12:03 AM   #3
Rewards Points: 160
Distribution box for low-voltage AC circuits? Like 24 V AC? Just a wild guess as I can't say I've ever seen one like this. Also don't recognize the panel on the left -- fuse or breaker?
philS is offline   Reply With Quote
Old 06-04-2013, 12:10 AM   #4
" Euro " electrician
frenchelectrican's Avatar
The panel on left is Pushmatic aka Bulldog breakers.
They are good but hard to find parts plus those breakers are not " slip on " they are actual bolt on breaker type.
Merci,
Marc
Old 06-04-2013, 12:29 AM   #5
Rewards Points: 452
so what about that ground wire exposed on the outside?
My tenants have kids who might touch it
Old 06-04-2013, 12:38 AM   #6
Rewards Points: 160
Yup, figure out where they lead (if you can). Do you maybe have low voltage garden lights? Also would help if you checked voltage of those thin wires coming off the distribution bar beneath the transformer. Rules for 24 V AC are a lot looser than for 120 V.
Old 06-04-2013, 12:44 AM   #7
simple ., dig up a small trench and push the ground wire down deeper and use the homemade stake* to hold the bare conductor down.
Merci,
Marc
* something like what they used to hold the tent or something simauir to that.
Old 06-04-2013, 01:48 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 2,140
With that many wires, sort of rules out door bell....
I'm thinking home grown alarm system. The 24V might be for door/window sensors.
The Following User Says Thank You to ddawg16 For This Useful Post:
Speedy Petey (06-04-2013)
Old 06-04-2013, 04:51 AM   #9
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
lighting switches old skool .....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 06-04-2013, 05:27 AM   #10
MarginallyQualified
Turn off the power. Tenant kids will be safe.
Are we to guess at what the wires are for?
I'll put a nickle on electric fence.
Old 06-04-2013, 05:46 AM   #11
Rewards Points: 764
I'm going to take a wild guess that it's a well pump controller. They frequently have a LV control system when there is more than one pump.
Mark
busman is offline   Reply With Quote
Old 06-04-2013, 10:29 PM   #12
Rewards Points: 1,192
My favorite jobs are hearing the former occupant was an electrician in a steel mill or a mine. That's what the work always looks like.
bobelectric is offline   Reply With Quote
Old 06-04-2013, 10:35 PM   #13
Merci,
Marc
The pushmatic breakers are readily available here ,mfg. by American Breaker Co. They also make replacement FPE breakers.
Old 06-04-2013, 11:50 PM   #14
Yeah for the common size up to 60 amp two pole pushmatic's but once you get over 60 amps then it will change the game a bit it will be much harder to find them espcally with P2100 breakers which I have order it from time to time but not very often.
Note: just becarefull with P2100 they actually come in two verison one is convetnail main breaker set up and branch circuit breaker due the bussbar tab are differnt between the two's.
Merci,
Marc
Old 06-05-2013, 01:51 AM   #15
Rewards Points: 452
nope. not a guessing game.
Just thought you guys might have seen something like this before, and wondering if I need to make a cover for it.
Electrical Wiring for Separate Garage HomeGuy2 Electrical 11 03-15-2013 10:50 PM
Installing 220 in garage for future welder - questions! wguttrid Electrical 7 01-31-2013 07:30 AM
Electrical Upgrade: Detached Garage LATiger Electrical 9 06-05-2012 05:44 PM
electrical circuit in a garage acs4mkt Electrical 2 04-07-2012 02:45 PM
Garage electrical. Moose71 Electrical 5 01-01-2010 08:31 PM
