Electrical Box/Fixture Screw Alignment Disparity - Electrical - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 02:22 PM   #1
Electrical box/Fixture screw alignment disparity
I am replacing a porch light fixture. The screw holes in the elecrtical box are in a diagonal position; however, the fixture requires that they are ia a horizontal position. What is the correct way to install the fixture, so that it is safe and firmly attached to the wall?
1str8arrow is offline   Reply With Quote
Old 05-10-2013, 02:34 PM   #2
JW
mm11's Avatar
Rewards Points: 614
The new fixture should come with something like this bracket-
mm11 is offline   Reply With Quote
The Following User Says Thank You to mm11 For This Useful Post:
Speedy Petey (05-10-2013)
Old 05-10-2013, 03:52 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Pictures and all. Perfect reply.
Old 05-10-2013, 04:59 PM   #4
Rewards Points: 150
possible code violation
usair is offline   Reply With Quote
Old 05-10-2013, 05:06 PM   #5
Oso954's Avatar
Rewards Points: 1,106
Why don't you expand on that (tell us what you think it is) rather than having us guess at it ?
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
MTN REMODEL LLC (05-11-2013)
Old 05-10-2013, 05:11 PM   #6
Thumbs up
Thanks mm11
Thank you for your help with this. I will use the solution you suggested.
Much appreciated,
--1str8arrow
Old 05-10-2013, 05:18 PM   #7
Sparky
Rewards Points: 510
Bracket is mounted to box with #6 screws, if fixture weighs more than 6lbs, you'll violate 314.27
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
1str8arrow (05-10-2013)
Old 05-10-2013, 05:52 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
And if that box is mounted on the ceiling you also violate 314.27.
Old 05-11-2013, 01:48 AM   #9
Rewards Points: 6,652
Really, and what would that be.
Old 05-11-2013, 01:52 AM   #10
What general light fixture for a porch light, that is going to weigh more than a pound or two. Really reaching out there on that one. Unless it is a McMansion, the picture is fine for a reference, and not to be taken as the law of the land.
Boy, a couple of you are really reaching out into never never land on this one, when all it is, is a picture to give reference to the OP question. Nothing was stated or referenced as to the type of fixture or the weight of the fixture.
Of course that bracket is not meant for a heavy butt-ass fixture,it is meant for most that are called Jelly jar, or most that you will find are nothing but plastic, and weigh no more than two or three pounds with the glass globe.
Old 05-11-2013, 05:39 AM   #11
E2 Electrician
We have no idea what light fixture he purchased, or box that is installed in the OP's scenario. Also the bracket is not the code violation, it's the 6-32 screws that would become the issue.
You may have jelly jar and plastic fixtures on your house, but we're not all like that. I've wired plenty of non- Mcmansion type houses that had fixtures over 6 lbs.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Jim Port (05-11-2013)
Old 05-11-2013, 07:17 AM   #12
That is a Home Depot/Lowes/Hampton Bay/crap fixture bracket.
I don't think I've EVER put one of those up that weighed more than 2#.
Old 05-11-2013, 09:12 AM   #13
Rewards Points: 150
not everyone buys cheap fixtures
The Following User Says Thank You to usair For This Useful Post:
stickboy1375 (05-11-2013)
Old 05-11-2013, 09:40 AM   #14
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,758
Works fine on the ceiling for the trapeze my wife and I have in the bedroom
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
gregzoll (05-11-2013)
Old 05-11-2013, 09:44 AM   #15
And if you connect that black wire to the white wire, I'm pretty sure it's a code violation.... although I can't site the reference
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 07:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
Electrical Box screw sizes jamiedolan Electrical 2 12-15-2008 03:33 PM
