Electrical Box For In Brick Walls - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 09:25 PM   #1
Rewards Points: 184
Electrical box for in brick walls
I'm in the process of renovating an old brick garage. Mason going to be starting brick repairs and repointing. I would like to have 1 light on each side of the garage door on the brick wall, but I'm not sure what is the exact type of box I need to have on hand for him to put in.
Can anyone post a link or picture showing the correct type?
Also the brick wall is 2 layers thick and the inside of garage will be framed out with 2x4's.
Does the mason just need to leave like an 1" or so hole open though the back layer of brick to feed the wire from the box to inside of framing, or does this wire need to be in conduit?
stevekem is offline   Reply With Quote
Old 09-28-2012, 09:56 PM   #2
Master Electrician
Rewards Points: 3,820
Use one of these with a short piece of emt or liquid tight non-metallic conduit out the back into the framing.
brric is offline   Reply With Quote
Old 09-28-2012, 10:06 PM   #3
Rewards Points: 184
Awesome, thanks for the pics.... Anyone know a good height to mount these at? I know it might vary depending on the type of fixture, but is there a rule of thumb to go by?
Old 09-28-2012, 10:47 PM   #4
Code05's Avatar
Rewards Points: 1,104
6' to 6'6" usually works fine.
Code05 is offline   Reply With Quote
Old 09-29-2012, 11:54 AM   #5
Rewards Points: 184
Great, thanks!
Old 09-29-2012, 12:14 PM   #6
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
Right where your red stripes in the picture will look good.
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
white triangle lines on both side walls around my brick chimney. peter101 Roofing/Siding 11 10-11-2011 08:20 AM
repairing electrical outlets in old Plaster lath walls jjchips Carpentry 3 09-04-2010 10:20 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
Deteriorating brick walls jelost Building & Construction 2 03-15-2009 08:21 PM
Old Brick House inside walls rick32 Building & Construction 6 11-08-2007 06:49 PM
