Electrical Box - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 05:58 AM   #16
Flashers...
if you can show me what you mean it would help
I kinda understand u are talking about coming from the bottom of the
Meter to the New Garage.
The distance to the New Garage would only be 12 feet straight to the New Garage from the side of the house ( in that area ) so I would have to
bury the wire in ground ( all my utilities are under ground here )
so that means put in some kind of Plastic Conduit I would imagine.
True about jumping ahead but when you are on Craigs List and u find
something you have to Pounce on it first or its GONE... lol.
Teammuir1 is offline   Reply With Quote
Old 10-18-2012, 07:13 AM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would NEVER buy equipment meant for personal and home protection from some guy on Craigslist. Take a trip to one of the home improvement stores, panels are not that expensive.
Old 10-18-2012, 08:13 AM   #18
Rewards Points: 3,130
Originally Posted by Teammuir1 View Post
if coming off the bottom lugs like you described is independent from the
home then wouldnt that mean that I would have a seperate meter for the garage?
please every one I am NEW to alot of the terminology so please
bear with me.
I know my house has a 200 amp service in the house but I am not
sure what at the meter.
How can I find out?
Contact your power company.
Old 10-18-2012, 10:16 AM   #19
Common Sense Common Guy
Rewards Points: 161
No...
here's a (very simplified) diagram of how mine was connected. Note that I'm not showing the earthing safety system here (ground rods and connections). This shed was built in early 2008, and there are no other metallic paths between home and shed. Be sure you understand safety and grounding requirements for your particular case, or call an electrician.
As mentioned earlier, call your PoCo and ask what service you have from the transformer to your home. If your service from the pole is not all that big (when I did this, I found my home was on a 15 kVA transformer fed by 2/0 AL), you'll likely need the PoCo to help upgrade that portion too, depending on your expected loads. In my case, the PoCo's study showed I was drawing that transformer far over its rated capacity sometimes, and I expected to add 20 kW of electric car charging loads, plus my occasional machine needs (welder, etc.); they had to bump me up.
flasherz is offline   Reply With Quote
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
