Electrical Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 09:12 PM   #1
electrical box
I have a box with 2 switches, one control 1 lamp, the other 4 lamps.
Out from the wall are 4 cables, cable 1 goes to switch 1 cable 2 goes to switch 2 and cables 3 & 4 are tapped together with the ones coming out from switches
1 & 2 ( all are black! ), The 4 white cables are tapped together.
I bought a single switch to turn the 4 lamps independently, how can i do it????
The new switch has 4 gold screws, 2 on each side and 1 black on the sided bottom, plus the green ground on top. Thank you in advance, hope you can understand. Archi
archi is offline   Reply With Quote
Old 10-17-2011, 09:24 PM   #2
Rewards Points: 6,652
Really need a drawing or picture, due to hard to visualize. Do not need to know what color goes to what screw, just need to know which is power, and which goes to what light in the drawing. As for your post, are you asking a question regarding how it should be wired, or are you just telling everyone what you found out, when you took the wall plate off.
The Following User Says Thank You to gregzoll For This Useful Post:
archi (10-18-2011)
Old 10-17-2011, 09:37 PM   #3
electric box
Hi, Gregzoll: Yes i want to know how to wire the new switch, with what i found at the box, i don't think i could send a picture or drawing.
Old 10-17-2011, 09:46 PM   #4
Just draw it out in Paint. That is the easiest way to do it. Post a picture also of what the junction box wiring looks like currently.
archi (10-18-2011)
Old 10-17-2011, 10:17 PM   #5
picture of electrical box
did you received the pictures of the box, Gregzoll? Archi
Old 10-17-2011, 10:47 PM   #6
You need to post them as a public post on this thread.
archi (10-18-2011)
Old 10-18-2011, 02:44 AM   #7
electical box pictures
I don't know how to post them as a public post on this thread, but thanks any way.
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
