Electrical Bonding - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2007, 09:27 PM   #1
Electrical bonding
I am installing an electrical panel to a pole barn. The barn is a wood structure with metal roof and siding. I was told by local vendor that I need to bond the siding (he didn't say anything about roof) and water supply to the panel. Is this just a matter of tying to two together with conductor or is there something else I need to do? Also,why is this necessary?
timdwoodworking is offline   Reply With Quote
Old 12-11-2007, 09:42 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
The water must be bonded as it is expressly stated in the code. The siding only is suggested to be bonded if it is likely to be energized. IMO this is not likely.
Here is the NEC Handbook commentary on this:
Because metal siding on buildings is not electrical equipment, it is outside the scope of the Code [see 90.2(A)]. Therefore, the Code cannot require that it be grounded. Quite often, however, luminaires, signs, or receptacles are installed on buildings with metal siding that could become energized. Grounding of metal siding reduces the risk of shock to persons who may come in contact with siding that has become energized.
Old 12-11-2007, 09:55 PM   #3
Electrician
Just an example.
chris75 is offline   Reply With Quote
Old 12-11-2007, 10:02 PM   #4
Thanks a bunch to both of you for the reply!
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 11:19 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
Which bonding method proper??? Nestor Electrical 2 09-15-2006 07:18 AM
